LibreELEC Krypton/Leia/Agile 64bit kernel 32bit libs
(03-20-2018, 10:16 AM)krill42 Wrote: Hi all,
thank you for the great Job !
I have just installed leia24 on a rock64 and it worked OOTB with an HDMI Cable plugged on my AVR.
Then I have tried to enable Audio HDMI digital passthrough for my Pioneer VSX2020K AVR and it didn't go well... the horrible pfrfrpfrp sound prevents me from enjoyoing the neat image.
Does anyone has some insight as to what to look for ?
Do I have to set something other than enable passthrough and some digital codecs like dts/ac3/etc ?
Krill42
DTS HD-MA and Dolby TrueHD as passthrough are still work in progress I assume as I can confirm white noise or silence when activated for DTS HD-MA and Dolby TrueHD on a Onkyo TX-NR-1010.
On the Onkyo display it shows the correct audio format as either DTS HD-MA or Dolby TrueHD... but no sound.
My workaround is to switch to downmix to PCM which sounds OK.
RE: LibreELEC Krypton/Leia/Agile 64bit kernel 32bit libs - by Willem53 - 03-21-2018, 07:01 AM
  Libreelec nfs shares nberg@xs4all.nl 0 625 11-11-2022, 01:18 PM
Last Post: nberg@xs4all.nl
  Linux 5.15 Kernel - openSuse mark1250 0 1,243 12-02-2021, 04:36 PM
Last Post: mark1250
  Security Patches for the Kernel kwinz 9 6,547 10-22-2021, 05:45 AM
Last Post: kwinz
  Debian kernel stuck at 4.4.167 Enig123 5 5,478 12-29-2020, 12:57 PM
Last Post: kwinz
  Arch Linux Arm --> Kernel 5.8 breaks installation as365n4 12 11,973 08-31-2020, 01:41 AM
Last Post: as365n4
  mainline kernel sound support Openwrt lucize 2 3,990 05-01-2020, 05:09 PM
Last Post: PakoSt
  5.3 kernel support? csrf 5 6,930 04-18-2020, 11:34 PM
Last Post: CameronNemo
  Help troubleshooting kernel panic gabrielfin 3 4,540 03-02-2020, 04:18 PM
Last Post: gabrielfin
  need a dts file to set some pins as pulldown interrupts in kernel using a DTO dkebler 0 1,969 02-05-2020, 10:58 PM
Last Post: dkebler
  Any advantages to using the mainline kernel dkebler 0 2,081 11-16-2019, 12:17 PM
Last Post: dkebler
