LibreELEC Krypton/Leia/Agile 64bit kernel 32bit libs
#62
(11-27-2017, 10:14 AM)Mrfixit2001 Wrote: @Raybuntu - sorry if I wasn't clear, I wasn't asking about Retroplayer, I was asking about emulationstation and retroarch as stand alone packages that are called from KODI. When run, kodi would exit and that package would open. From my understanding, that is quite different than Retroplayer, but maybe I have been misinformed? One thing is for sure, using the most recent release that you have for the ROCK64, when I install the emulationstation and retoarch apps in KODI, they do not launch. That's the root of the issue I'm trying to accomplish.
Here's a link to a LibreELEC build that I believe does what I'm after, however this below build is not available for the ROCK64 and I don't believe it has your 64-bit kernel with 32-bit user space. So I am trying to accomplish one of two things... update the below build to support ROCK64 with 64-bit kernel and 32-bit user space, or preferably use your build and just add what's missing to accomplish the same thing that the below build does.
https://forum.libreelec.tv/thread/302-le...-problems/
From what I can tell, Retroplayer doesn't perform as well as the native emulationstation and retroarch do, which is what's driving me to want this. Hope that all makes sense. I welcome any and all feedback, suggestions, and guidance!
I never tried retroarch. I suggest you try Lakka cause it's more focused on retroarch/emulationstation.
RE: LibreELEC Krypton/Leia/Agile 64bit kernel 32bit libs - by Raybuntu - 11-28-2017, 05:59 AM
  Libreelec nfs shares nberg@xs4all.nl 0 657 11-11-2022, 01:18 PM
Last Post: nberg@xs4all.nl
  Linux 5.15 Kernel - openSuse mark1250 0 1,275 12-02-2021, 04:36 PM
Last Post: mark1250
  Security Patches for the Kernel kwinz 9 6,733 10-22-2021, 05:45 AM
Last Post: kwinz
  Debian kernel stuck at 4.4.167 Enig123 5 5,609 12-29-2020, 12:57 PM
Last Post: kwinz
  Arch Linux Arm --> Kernel 5.8 breaks installation as365n4 12 12,224 08-31-2020, 01:41 AM
Last Post: as365n4
  mainline kernel sound support Openwrt lucize 2 4,048 05-01-2020, 05:09 PM
Last Post: PakoSt
  5.3 kernel support? csrf 5 7,049 04-18-2020, 11:34 PM
Last Post: CameronNemo
  Help troubleshooting kernel panic gabrielfin 3 4,630 03-02-2020, 04:18 PM
Last Post: gabrielfin
  need a dts file to set some pins as pulldown interrupts in kernel using a DTO dkebler 0 2,007 02-05-2020, 10:58 PM
Last Post: dkebler
  Any advantages to using the mainline kernel dkebler 0 2,113 11-16-2019, 12:17 PM
Last Post: dkebler
