LibreELEC Krypton/Leia/Agile 64bit kernel 32bit libs
#40
(11-16-2017, 04:06 PM)Sauromayne Wrote:
(11-16-2017, 03:56 PM)Luke Wrote:
(11-16-2017, 02:10 PM)Sauromayne Wrote: Hey guys. I recently ordered a Rock64 and am looking at installing this build. It’s my understanding that I need to burn the img.gz file to an SD card correct? Can I do this with the LibreElec SD creator or should I use some other tool?
Also, I’m wondering what the tar file is used for?
I plan on using this device for streaming 1080p on Kodi mainly. Does it perform that well right now. I didn’t enough research I guess because I wasn’t aware it was so new in development.
Thanks for any help!
Please refer to the wiki NOOB section for detailed explanation on how to flash images - this image flashes like any other.
Thank you for the link that will help a lot with the flashing process. I’m still curious to know what the TAR file is for and how well the rock64 streams on Kodi if anybody has any input on that.
The TAR file is for updates. You only need to flash the img ones. After that you can just place the tar in /storage/.update and reboot. LibreELEC will upgrade or downgrade to my latest or previous version.
RE: LibreELEC Krypton/Leia/Agile 64bit kernel 32bit libs - by Raybuntu - 11-17-2017, 12:47 AM
  How to boot an older, working kernel bits 0 1,746 11-01-2024, 04:43 PM
Last Post: bits
  Libreelec nfs shares nberg@xs4all.nl 0 1,466 11-11-2022, 01:18 PM
Last Post: nberg@xs4all.nl
  Linux 5.15 Kernel - openSuse mark1250 0 2,325 12-02-2021, 04:36 PM
Last Post: mark1250
  Security Patches for the Kernel kwinz 9 11,442 10-22-2021, 05:45 AM
Last Post: kwinz
  Debian kernel stuck at 4.4.167 Enig123 5 8,782 12-29-2020, 12:57 PM
Last Post: kwinz
  Arch Linux Arm --> Kernel 5.8 breaks installation as365n4 12 18,022 08-31-2020, 01:41 AM
Last Post: as365n4
  mainline kernel sound support Openwrt lucize 2 6,125 05-01-2020, 05:09 PM
Last Post: PakoSt
  5.3 kernel support? csrf 5 10,203 04-18-2020, 11:34 PM
Last Post: CameronNemo
  Help troubleshooting kernel panic gabrielfin 3 6,727 03-02-2020, 04:18 PM
Last Post: gabrielfin
  need a dts file to set some pins as pulldown interrupts in kernel using a DTO dkebler 0 2,962 02-05-2020, 10:58 PM
Last Post: dkebler
