Brushless Fan (5v) for Rock64 Clear Case Soft PWM Drive 2N2222
The Rock64-A machine is cased in Dustin's C4Labs acrylic Zebra case ( Emerald ) .  The induction blower assembly is positioned behind the Zebra case, and the plastic insert on the power edge of the Zebra case has been removed.  Cool airflow is forced across the heatsink fins and is exhausted out the top via the gpio(s) port opening.
This is a more efficient system than the Rock64-B enclosure, as you can see by the health report(s). The fan assembly is mounted to a foam block ( very quiet ) which holds the induction blower at just the right height to match the opening.
I have been actively cooling my RPi(s) with this method for some time; its been a good system.
RE: Brushless Fan (5v) for Rock64 Clear Case Soft PWM Drive 2N2222 - by MarkHaysHarris777 - 09-02-2017, 05:17 AM
  Are HW design files available for ROCK64? irenek 3 4,525 12-11-2023, 09:31 PM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 0 278 11-23-2023, 05:05 AM
Last Post: ReleaseTheGeese
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 974 04-26-2023, 11:38 PM
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 0 576 03-21-2023, 03:48 PM
Last Post: o1CRiMSON1o
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 13,038 01-15-2023, 10:36 AM
Last Post: ds00
  rock64 totally brick dakobg 2 1,646 11-07-2022, 05:45 PM
Last Post: olivercfc
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 3,407 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
  Where can I find the ROCK64 POE HAT Zoz 2 2,497 06-08-2022, 12:44 AM
Last Post: Zoz
Smile wooden case for ROCK64 killor 13 16,163 03-04-2022, 06:56 AM
Last Post: killor
  1wire DS18b20 on Rock64? mypineme 6 6,820 09-28-2021, 03:07 PM
Last Post: TRS-80
