Screen backlight accidentally zero %
Just go into a dark room with a flashlight, and if you use the flashlight on the pinebooks screen, you can see what is going on it, with a little bit of patience you can get yourself into settings and move the brightness slider back up Wink
Screen backlight accidentally zero % - by boubik - 08-27-2017, 12:55 PM
RE: Screen backlight accidentally zero % - by TomC601 - 09-04-2017, 01:10 PM
  pinebook black screen when booting with "different power mode than last used" penzoiders 12 27,755 04-27-2020, 06:27 AM
  Failure in setting the display backlight with Armbian 5.86 [SOLVED] wlad 0 3,252 06-11-2019, 03:36 AM
Last Post: wlad
  Blank Screen on Boot MECZero 4 10,617 05-12-2019, 11:54 AM
Exclamation Armbian - need help, locked out myself by setting backlight to zero UltraBloxX 6 11,333 03-31-2019, 12:36 PM
Last Post: guidol
  How to Configure Screen Brightness in mate on pinebook via terinal? shirman 6 13,877 12-02-2018, 05:37 AM
Last Post: mikee3000
  Pinebook Ubuntu XFCE screen resolution options Fox7799 2 6,489 12-01-2018, 06:05 PM
Last Post: Fox7799
  Dimmed screen too much in plasma boballen55 1 4,855 11-09-2018, 03:42 PM
Last Post: boballen55
  How to test the emmc(usdhc2) diver and pwm backlight driver? vinothkumar 0 2,984 12-29-2017, 11:40 PM
Last Post: vinothkumar
