Mount a HeatSink on the Rock64 using 3M Thermal Tapes
Lightbulb
Tonight I'm going to be mounting a heatsink on my production Rock64 board ( using a nice heatsink I pulled from an old Epson printer stepper controller board -- the old style TO-220 heatsink ).  I'm also using thermal tape from 3M ( blue ) which serves the double function of thermal conductance as well adhesive for physical integrity.
The heatsink in the pic is about 25x15x14 mm.
Before you begin its a good idea to jot down the board info about your SoC if you're interested;  or like I've done here take a quick pic of it.  Once we stick the heatsink down with the 3M thermal tape, it is not going to be easy to get it off;  I've even known one guy to pull his SoC off the board because the balls gave way before the tape did !
I usually cut the 3M thermal tape just larger than the heatsink and then I trim it back with cuticle scissors. You do not want the heatsink (aluminum in this case) to touch any of the components on any side;  also don't worry about covering over any components. Peel the protective mylar backing away one at a time;  tape the heatsink first, then trim, then remove the other backing mylar,  and then gently place the heatsink over the SoC.
This pic shows the heatsink mounted and doing its thing!  With just passive cooling the temps went from mid to high 40s ℃  to mid to high 30s ℃ !  This heatsink is a little beefier than the ones I put on my Pines or Pis, and it certainly performs well even without the fan ( which is coming next week ).
Rolleyes
Mount a HeatSink on the Rock64 using 3M Thermal Tapes - by MarkHaysHarris777 - 08-23-2017, 07:40 PM
  Are HW design files available for ROCK64? irenek 3 4,702 12-11-2023, 09:31 PM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 0 318 11-23-2023, 05:05 AM
Last Post: ReleaseTheGeese
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 1,041 04-26-2023, 11:38 PM
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 0 612 03-21-2023, 03:48 PM
Last Post: o1CRiMSON1o
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 13,165 01-15-2023, 10:36 AM
Last Post: ds00
  rock64 totally brick dakobg 2 1,711 11-07-2022, 05:45 PM
Last Post: olivercfc
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 3,477 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
  Where can I find the ROCK64 POE HAT Zoz 2 2,579 06-08-2022, 12:44 AM
Last Post: Zoz
Smile wooden case for ROCK64 killor 13 16,443 03-04-2022, 06:56 AM
Last Post: killor
  1wire DS18b20 on Rock64? mypineme 6 6,964 09-28-2021, 03:07 PM
Last Post: TRS-80
