Powering up and down USB
Please see this schematic, page 9 of 19
You will notice that the two regulators EN line(s) ( similar to the Rock64 regulators ) are tied directly to Vcc-5v|usb-5v;  consequently the regulators are ON all the time.
If you look at the PMIC page ( power management integrated circuit ) you will see on the left bottom that the usb-5v is tied directly to Vcc-5v;  and you will further notice that the Vcc-5v is tied either directly to DCIN ( 5v ) or the 5v regulator from battery based on the  DC5v-Batt power jumper ( PMIC page top left ).
So the bottom line is that the usb 5v is always ON based on a physical jumper setting;  however,  this is where it gets interesting !
... because the jumper doesn't have to be a physical jumper connector;  it can also be a relay ( or electronic switch of some kind ) that is activated via gpio(s) !   So, although the board is not wired internally for this support ( like the Rock64 is ) it is wired to be allowed via external control because of the DC5v-Batt power jumper !
Shy
Powering up and down USB - by reverend_t - 08-17-2017, 11:27 AM
RE: Powering up and down USB - by reverend_t - 08-17-2017, 01:04 PM
RE: Powering up and down USB - by reverend_t - 08-17-2017, 03:54 PM
RE: Powering up and down USB - by MarkHaysHarris777 - 08-17-2017, 08:24 PM
RE: Powering up and down USB - by reverend_t - 08-21-2017, 06:11 AM
  PINE64 board not powering up loki21century 2 6,957 11-25-2019, 12:19 PM
Last Post: Partymack711
  Pine64 not powering up. skylab 5 9,731 05-03-2019, 02:48 PM
Last Post: Mendota
  Need some help on powering 16 PINEs pineresearch 13 21,796 04-01-2017, 02:33 AM
Last Post: longsleep
  Pine A64 not powering up / Power button missing vaevictis 10 18,019 07-06-2016, 01:28 PM
Last Post: xalius
