Kali Linux
(12-16-2015, 05:25 AM)tkaiser Wrote: If you want it slow --> choose Kali (unless Kali also supports the arm64 architecture and not only armhf the '64 bit' the Pine64+ is advertised with are pretty useless for you). And whether you need 4GB RAM is a question that only you yourself can answer. At least you're not able to use more than 2 GB since the A64 SoC used on Pine64+ can't deal with more physical RAM.
In other words: Kali will be available since every armhf Linux flavour will be available sometimes in the future (sadfully -- I would suspect some crazy mind will even give Raspbian with ARMv6 code a try). You won't see great performance improvements unless Kali adopts changes to support also arm64/ARMv8. But since Kali is just another Debian and Debian already supports ARMv8 someone a bit familiar with Kali will be able to switch from armhf to arm64 in the build scripts easily.
Again: That's not important at all. The magic happens somewhere else since without proper driver support for the A64 (and more recent kernel version) every Linux flavour on the Pine64 will feel a bit crappy.
Thanks for the clarification  Smile
Kali Linux - by monmoonmooonmoooon - 12-16-2015, 04:03 AM
RE: Kali Linux - by tkaiser - 12-16-2015, 04:25 AM
RE: Kali Linux - by monmoonmooonmoooon - 12-16-2015, 04:28 AM
RE: Kali Linux - by tkaiser - 12-16-2015, 05:25 AM
RE: Kali Linux - by monmoonmooonmoooon - 12-16-2015, 05:33 AM
RE: Kali Linux - by joe - 12-16-2015, 05:57 AM
RE: Kali Linux - by monmoonmooonmoooon - 12-16-2015, 06:02 AM
RE: Kali Linux - by joe - 12-16-2015, 06:22 AM
RE: Kali Linux - by monmoonmooonmoooon - 12-16-2015, 06:23 AM
RE: Kali Linux - by retired firefighter - 12-19-2015, 12:52 PM
RE: Kali Linux - by tllim - 12-19-2015, 05:13 PM
RE: Kali Linux - by deanMKD - 12-29-2015, 07:30 AM
RE: Kali Linux - by astaunton - 01-11-2016, 12:52 PM
RE: Kali Linux - by retired firefighter - 01-11-2016, 01:36 PM
RE: Kali Linux - by monmoonmooonmoooon - 01-12-2016, 03:25 AM
RE: Kali Linux - by scnd - 08-31-2016, 11:35 AM
RE: Kali Linux - by UnixOutlaw - 09-06-2016, 01:04 AM
RE: Kali Linux - by Ghelorn - 09-08-2016, 04:01 PM
  NEMS Linux 1.5 Released for A64/A64+, A64-LTS/SOPine, Rock64, RockPro64 (NAGIOS) Baldnerd 4 14,822 03-28-2020, 06:20 PM
Last Post: ty1911
  Howto run Linux with resolution other than 1080p longsleep 28 84,858 06-13-2019, 01:53 AM
Last Post: Nilda
  NEMS Linux for Pine A64 (+) Luke 1 8,247 05-09-2019, 05:42 PM
Last Post: pineadmin
  Pine Board using linux stuck during boot sequence ktaragorn 4 12,866 03-30-2019, 06:48 AM
Last Post: ktaragorn
  Gentoo Linux test image xalius 23 63,275 01-28-2019, 11:05 PM
Last Post: necrose99
  Real-time linux kernel Artyom 45 104,720 09-11-2018, 01:08 AM
Last Post: zzwpine
  linux distribution hazerty 3 8,939 04-01-2018, 02:48 PM
Last Post: dkryder
  Linux Web Server OS harcrow 2 8,014 01-30-2018, 10:26 AM
Last Post: Rustproof
  eta linux image?? firosiro 1 5,839 08-03-2017, 10:05 PM
Last Post: pfeerick
  Can I run Alpine Linux on Pine64? douglasmiranda 3 11,011 08-01-2017, 07:20 AM
Last Post: cztian
