Read if you experience issues with screen flickering
(08-04-2017, 09:02 AM)Luke Wrote: It seems that the newest batch (as of 04/08/2017) of Pinebooks shipped with an older Ubuntu image based on 3.10.105-bsp-1.2-ayufan-59 (you can check if your's is running this version by typing uname -a in terminal).
Some Pinebook's experience screen flickering while running this kernel version, which is solved by upgrading to newest release version.
To update your installation navitgate to /usr/local/sbin and run the following update scripts:
sudo ./pine64_update_kernel.sh 0.6.2
sudo ./pine64_update_uboot.sh 0.6.2
sudo ./pine64_update_package.sh 0.6.2
Run all three and then reboot.
I've got annoying flickers on the screen of my new Pinebook. I noticed them right after I had turned on my Pinebook :/ So, then I tried to update as it is recommended above but that didn't fix that issue. Any suggestions?
PS At least, I've managed to increase the sound
RE: Read if you experience issues with screen flickering - by atr.mbl - 08-15-2017, 12:37 PM
  Pinebook with a broken screen and 2 eMMC's for sale. UK ONLY. frank-zappa 0 1,653 03-08-2022, 10:14 AM
Last Post: frank-zappa
  Screen halo? caps 7 9,863 03-09-2021, 11:56 AM
Last Post: nasask8r
  Pinebook 14" smashed screen. frank-zappa 4 8,157 10-18-2020, 09:24 AM
  Screen staying dark. ocschwar 2 4,685 07-18-2020, 04:54 PM
Last Post: ocschwar
  New user - couple of issues sliberty 2 3,451 05-22-2019, 05:36 PM
Last Post: phuzy
  Pinebook Issues DannyJack 6 7,417 05-18-2019, 09:54 AM
Last Post: Surehand53
  Screen resolution heywire 5 7,126 04-03-2019, 01:42 PM
Last Post: bigCamel
  DCOP communications error (Welcome screen) jschall 2 3,591 11-17-2018, 02:33 PM
Last Post: jschall
  How to adjust screen brightness? jschall 4 6,685 11-15-2018, 12:38 PM
Last Post: jschall
  1080p mainline kernel issues e-minguez 2 3,468 11-14-2018, 02:54 PM
Last Post: e-minguez
