Linux Images (ROCK64)
#83
(01-25-2018, 04:54 AM)matteobp Wrote:
(01-24-2018, 10:07 AM)ayufan Wrote: matteobp: this is very strange, on USB3.0, on 4.4, on OMV, with FDE, over GbE I get around 80MB/s.
I have never seen this speed, not even in reading! Huh
In the weekend I'll try the latest stretch 0.6.15 - 175 with default  kernel 4.4.103.
I'll check the network performance using netperf with both windows and linux machine, and the USB3.0 local performance with iozone (but if I'm not mistaken it is over 100MB/s).
I can also make a test with Helios LAN test.
Do you need some particular log or output?
Thanks.
I did the test with the jessie OMV 0.6.19 and jessie OMV 0.5.15, using 3 different PC to read from and write to.
One PC with Windows 7, one notebook with Windows 10 and one PC with Ubuntu 16.04 LTS.
All of them have gigabit ethernet, and are directly connected to the router Netgear DGND3700v2 (gigabit ports).
I tried with 2 different ethernet cables to connect the rock64 to the router. The test was done with 1.5GB file.
The average read speed was less than 50MB/s and the average write speed was less than 40MB/s, and there are no significant difference with all of 3 PC.
So i can exclude problem with the "other" PC, and problem with cables.
This is the result of this command
iozone -e -I -a -s 500M -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2
Include fsync in write timing
O_DIRECT feature enabled
Auto Mode
File size set to 512000 kB
Record Size 512 kB
Record Size 1024 kB
Record Size 16384 kB
Command line used: iozone -e -I -a -s 500M -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2
Output is in kBytes/sec
Time Resolution = 0.000001 seconds.
Processor cache size set to 1024 kBytes.
Processor cache line size set to 32 bytes.
File stride size set to 17 * record size.
                                                      random    random
      kB  reclen    write  rewrite    read    reread    read     write
 512000     512   109522   109732   110923   111712    46086    65877
 512000    1024   108753   109736   109988   110808    63479    78590
 512000   16384   108623   109206   108038   110314   103154   104457
This is the result of this command (rock64 as client)
iperf -c x.y.z.3 -P 1 -i 1 -p 5xxx -f m -t 10 -T 1
Client connecting to x.y.z.3, TCP port 5yyy
TCP window size: 0.08 MByte (default)
[  3] local x.y.z.15 port 40xxx connected with x.y.z.3 port 5yyy
[ ID] Interval       Transfer     Bandwidth
[  3]  0.0- 1.0 sec   115 MBytes   962 Mbits/sec
[  3]  1.0- 2.0 sec   112 MBytes   936 Mbits/sec
[  3]  2.0- 3.0 sec   112 MBytes   943 Mbits/sec
[  3]  3.0- 4.0 sec   111 MBytes   933 Mbits/sec
[  3]  4.0- 5.0 sec   112 MBytes   936 Mbits/sec
[  3]  5.0- 6.0 sec   112 MBytes   942 Mbits/sec
[  3]  6.0- 7.0 sec   111 MBytes   934 Mbits/sec
[  3]  7.0- 8.0 sec   113 MBytes   947 Mbits/sec
[  3]  8.0- 9.0 sec   112 MBytes   940 Mbits/sec
[  3]  9.0-10.0 sec   112 MBytes   941 Mbits/sec
[  3]  0.0-10.0 sec  1122 MBytes   941 Mbits/sec
This is the result of this command (rock64 as server)
iperf -c x.y.z.15 -P 1 -i 1 -p 5yyy -f m -t 10 -T 1
Server listening on TCP port 5yyy
[  4] local x.y.z.15 port 5yyy connected with x.y.z.3 port 59xxx
[  4]  0.0- 1.0 sec   108 MBytes   908 Mbits/sec
[  4]  1.0- 2.0 sec   112 MBytes   941 Mbits/sec
[  4]  2.0- 3.0 sec   112 MBytes   941 Mbits/sec
[  4]  3.0- 4.0 sec   112 MBytes   941 Mbits/sec
[  4]  4.0- 5.0 sec   112 MBytes   941 Mbits/sec
[  4]  5.0- 6.0 sec   112 MBytes   941 Mbits/sec
[  4]  6.0- 7.0 sec   112 MBytes   941 Mbits/sec
[  4]  7.0- 8.0 sec   112 MBytes   942 Mbits/sec
[  4]  8.0- 9.0 sec   112 MBytes   941 Mbits/sec
[  4]  9.0-10.0 sec   112 MBytes   941 Mbits/sec
[  4]  0.0-10.0 sec  1120 MBytes   938 Mbits/sec
I think there is no problem with disk neither with gigabit transfer.
What is the problem? I don't know. Huh
But reading the forum, I'm not the only one having this problem.
Linux Images (ROCK64) - by pineadmin - 08-04-2017, 04:06 AM
RE: Linux Images (ROCK64) 0.4.16-83 - by pfeerick - 08-08-2017, 05:59 PM
RE: Linux Images (ROCK64) 0.4.16-83 - by senderg - 08-10-2017, 03:10 AM
RE: Linux Images (ROCK64) 0.4.16-83 - by Luke - 08-10-2017, 03:15 AM
RE: Linux Images (ROCK64) 0.4.16-83 - by senderg - 08-10-2017, 03:16 AM
RE: Linux Images (ROCK64) - by pineadmin - 08-16-2017, 03:59 AM
RE: Linux Images (ROCK64) - by stuartiannaylor - 08-21-2017, 09:10 PM
RE: Linux Images (ROCK64) - by MarkHaysHarris777 - 08-21-2017, 09:20 PM
RE: Linux Images (ROCK64) - by stuartiannaylor - 08-21-2017, 10:35 PM
RE: Linux Images (ROCK64) - by MarkHaysHarris777 - 08-21-2017, 11:29 PM
RE: Linux Images (ROCK64) - by stuartiannaylor - 08-21-2017, 11:44 PM
RE: Linux Images (ROCK64) - by radek - 08-21-2017, 11:59 AM
RE: Linux Images (ROCK64) - by Luke - 08-21-2017, 02:54 PM
RE: Linux Images (ROCK64) - by stuartiannaylor - 08-21-2017, 02:59 PM
RE: Linux Images (ROCK64) - by radek - 08-22-2017, 07:21 AM
RE: Linux Images (ROCK64) - by Luke - 08-22-2017, 07:32 AM
RE: Linux Images (ROCK64) - by Farley56 - 09-06-2017, 03:57 PM
RE: Linux Images (ROCK64) - by tllim - 09-06-2017, 06:31 PM
RE: Linux Images (ROCK64) - by Farley56 - 09-06-2017, 06:51 PM
RE: Linux Images (ROCK64) - by elatllat - 09-12-2017, 12:55 PM
RE: Linux Images (ROCK64) - by ayufan - 09-12-2017, 01:18 PM
RE: Linux Images (ROCK64) - by pineadmin - 09-12-2017, 11:56 PM
RE: Linux Images (ROCK64) - by Farley56 - 09-19-2017, 07:13 PM
RE: Linux Images (ROCK64) - by stuartiannaylor - 09-27-2017, 02:23 PM
RE: Linux Images (ROCK64) - by Farley56 - 09-27-2017, 06:16 PM
RE: Linux Images (ROCK64) - by stuartiannaylor - 09-27-2017, 07:45 PM
RE: Linux Images (ROCK64) - by pineadmin - 10-02-2017, 03:32 AM
RE: Linux Images (ROCK64) - by stuartiannaylor - 10-02-2017, 07:00 AM
RE: Linux Images (ROCK64) - by chitenavi - 10-24-2017, 12:26 AM
RE: Linux Images (ROCK64) - by Luke - 10-24-2017, 02:39 AM
RE: Linux Images (ROCK64) - by pineadmin - 10-24-2017, 02:30 AM
RE: Linux Images (ROCK64) - by chitenavi - 10-24-2017, 03:28 AM
RE: Linux Images (ROCK64) - by Luke - 10-24-2017, 03:57 AM
RE: Linux Images (ROCK64) - by chitenavi - 10-24-2017, 04:17 AM
RE: Linux Images (ROCK64) - by gene83 - 11-22-2017, 11:00 AM
RE: Linux Images (ROCK64) - by Rar9 - 12-04-2017, 10:14 AM
RE: Linux Images (ROCK64) - by Luke - 12-04-2017, 10:19 AM
RE: Linux Images (ROCK64) - by Rar9 - 12-04-2017, 11:19 AM
RE: Linux Images (ROCK64) - by Luke - 12-04-2017, 11:30 AM
RE: Linux Images (ROCK64) - by pineadmin - 12-08-2017, 04:42 AM
RE: Linux Images (ROCK64) - by thewonderer - 12-19-2017, 01:11 AM
RE: Linux Images (ROCK64) - by dkryder - 12-19-2017, 07:42 PM
RE: Linux Images (ROCK64) - by pineadmin - 12-21-2017, 12:27 AM
RE: Linux Images (ROCK64) - by Rar9 - 12-21-2017, 05:37 AM
RE: Linux Images (ROCK64) - by pineadmin - 12-22-2017, 04:24 AM
RE: Linux Images (ROCK64) - by Rar9 - 12-22-2017, 05:40 AM
RE: Linux Images (ROCK64) - by dkryder - 12-22-2017, 11:00 AM
Linux Images (ROCK64) - by Rar9 - 12-22-2017, 11:07 AM
RE: Linux Images (ROCK64) - by dkryder - 12-22-2017, 03:36 PM
RE: Linux Images (ROCK64) - by pineadmin - 01-04-2018, 04:58 AM
RE: Linux Images (ROCK64) - by gene83 - 01-13-2018, 05:38 PM
RE: Linux Images (ROCK64) - by xalius - 01-13-2018, 06:29 PM
RE: Linux Images (ROCK64) - by gene83 - 01-13-2018, 08:02 PM
RE: Linux Images (ROCK64) - by gene83 - 01-14-2018, 04:33 AM
RE: Linux Images (ROCK64) - by Luke - 01-14-2018, 08:58 AM
RE: Linux Images (ROCK64) - by thewonderer - 01-17-2018, 04:57 PM
RE: Linux Images (ROCK64) - by gene83 - 01-17-2018, 06:30 PM
RE: Linux Images (ROCK64) - by thewonderer - 01-17-2018, 06:45 PM
RE: Linux Images (ROCK64) - by gene83 - 01-17-2018, 11:06 PM
RE: Linux Images (ROCK64) - by a1w.ca - 01-17-2018, 11:52 PM
RE: Linux Images (ROCK64) - by Luke - 01-18-2018, 01:01 AM
RE: Linux Images (ROCK64) - by gene83 - 01-18-2018, 05:56 AM
RE: Linux Images (ROCK64) - by soichiro - 01-18-2018, 10:33 AM
RE: Linux Images (ROCK64) - by Luke - 01-18-2018, 10:38 AM
RE: Linux Images (ROCK64) - by soichiro - 01-18-2018, 11:07 AM
RE: Linux Images (ROCK64) - by thewonderer - 01-23-2018, 11:15 PM
RE: Linux Images (ROCK64) - by gene83 - 01-23-2018, 11:37 PM
RE: Linux Images (ROCK64) - by thewonderer - 01-24-2018, 12:16 AM
RE: Linux Images (ROCK64) - by matteobp - 01-24-2018, 03:35 AM
RE: Linux Images (ROCK64) - by ayufan - 01-24-2018, 10:07 AM
RE: Linux Images (ROCK64) - by matteobp - 01-25-2018, 04:54 AM
RE: Linux Images (ROCK64) - by matteobp - 02-06-2018, 11:02 AM
RE: Linux Images (ROCK64) - by thewonderer - 02-06-2018, 10:16 PM
RE: Linux Images (ROCK64) - by thewonderer - 01-24-2018, 05:27 PM
RE: Linux Images (ROCK64) - by Luke - 01-25-2018, 05:26 AM
RE: Linux Images (ROCK64) - by matteobp - 01-26-2018, 05:28 AM
RE: Linux Images (ROCK64) - by Luke - 01-26-2018, 06:04 AM
RE: Linux Images (ROCK64) - by gene83 - 01-25-2018, 05:39 AM
RE: Linux Images (ROCK64) - by Luke - 01-25-2018, 06:47 AM
RE: Linux Images (ROCK64) - by gene83 - 01-25-2018, 09:43 AM
RE: Linux Images (ROCK64) - by thewonderer - 01-25-2018, 04:34 PM
RE: Linux Images (ROCK64) - by Crady - 01-30-2018, 07:47 PM
RE: Linux Images (ROCK64) - by Luke - 01-31-2018, 01:33 AM
RE: Linux Images (ROCK64) - by gene83 - 02-06-2018, 12:59 PM
RE: Linux Images (ROCK64) - by gene83 - 02-07-2018, 08:43 AM
RE: Linux Images (ROCK64) - by Tony32 - 02-07-2018, 10:06 AM
Xenial Mate Cannot Install Add-ons - by Crady - 02-07-2018, 10:52 AM
RE: Linux Images (ROCK64) - by gene83 - 02-07-2018, 11:20 AM
RE: Linux Images (ROCK64) - by Crady - 02-07-2018, 11:47 AM
RE: Linux Images (ROCK64) - by gene83 - 02-07-2018, 02:04 PM
RE: Linux Images (ROCK64) - by Trash_Can_Man - 02-09-2018, 07:10 AM
RE: Linux Images (ROCK64) - by gene83 - 02-09-2018, 09:21 AM
RE: Linux Images (ROCK64) - by thewonderer - 03-01-2018, 08:29 PM
RE: Linux Images (ROCK64) - by prof7bit - 03-03-2018, 06:40 AM
RE: Linux Images (ROCK64) - by Ricky - 03-18-2018, 12:38 PM
RE: Linux Images (ROCK64) - by pfeerick - 03-18-2018, 09:15 PM
RE: Linux Images (ROCK64) - by Ricky - 03-19-2018, 07:04 AM
RE: Linux Images (ROCK64) - by t4_4t - 03-29-2018, 02:08 AM
RE: Linux Images (ROCK64) - by Malmgren - 04-02-2018, 05:30 AM
RE: Linux Images (ROCK64) - by WenYee - 04-08-2018, 02:38 AM
Linux Images (ROCK64) - by daniel.ligti - 05-06-2018, 01:40 AM
RE: Linux Images (ROCK64) - by rompelstompel - 05-14-2018, 04:38 AM
RE: Linux Images (ROCK64) - by jzhang18 - 05-29-2018, 01:20 PM
RE: Linux Images (ROCK64) - by evilbunny - 05-29-2018, 04:42 PM
RE: Linux Images (ROCK64) - by pfeerick - 05-29-2018, 05:27 PM
RE: Linux Images (ROCK64) - by jzhang18 - 05-31-2018, 07:43 PM
RE: Linux Images (ROCK64) - by pfeerick - 05-31-2018, 11:24 PM
RE: Linux Images (ROCK64) - by jzhang18 - 06-01-2018, 08:16 AM
RE: Linux Images (ROCK64) - by OnTheRocks - 05-30-2018, 03:52 AM
RE: Linux Images (ROCK64) - by evilbunny - 05-30-2018, 05:55 AM
RE: Linux Images (ROCK64) - by OnTheRocks - 05-30-2018, 09:13 PM
RE: Linux Images (ROCK64) - by evilbunny - 05-30-2018, 09:45 PM
RE: Linux Images (ROCK64) - by jzhang18 - 06-02-2018, 09:25 AM
RE: Linux Images (ROCK64) - by pfeerick - 06-02-2018, 10:50 PM
RE: Linux Images (ROCK64) - by t4_4t - 06-02-2018, 02:38 PM
RE: Linux Images (ROCK64) - by jzhang18 - 06-03-2018, 09:17 AM
RE: Linux Images (ROCK64) - by t4_4t - 06-04-2018, 01:25 AM
RE: Linux Images (ROCK64) - by jzhang18 - 06-04-2018, 02:38 PM
RE: Linux Images (ROCK64) - by jzhang18 - 06-05-2018, 10:14 AM
RE: Linux Images (ROCK64) - by gregb49 - 06-21-2018, 11:41 AM
RE: Linux Images (ROCK64) - by pfeerick - 06-21-2018, 06:07 PM
RE: Linux Images (ROCK64) - by gregb49 - 06-22-2018, 12:14 AM
RE: Linux Images (ROCK64) - by gregb49 - 06-22-2018, 12:25 AM
RE: Linux Images (ROCK64) - by pfeerick - 06-22-2018, 04:38 PM
RE: Linux Images (ROCK64) - by gregb49 - 07-17-2018, 10:23 AM
RE: Linux Images (ROCK64) - by Trash_Can_Man - 07-17-2018, 11:34 AM
RE: Linux Images (ROCK64) - by gregb49 - 07-17-2018, 01:03 PM
RE: Linux Images (ROCK64) - by Trash_Can_Man - 07-17-2018, 01:35 PM
RE: Linux Images (ROCK64) - by gregb49 - 07-17-2018, 04:16 PM
RE: Linux Images (ROCK64) - by Trash_Can_Man - 07-17-2018, 04:24 PM
RE: Linux Images (ROCK64) - by gregb49 - 07-18-2018, 02:46 AM
RE: Linux Images (ROCK64) - by gregb49 - 07-22-2018, 09:21 AM
RE: Linux Images (ROCK64) - by gene83 - 07-22-2018, 08:56 PM
RE: Linux Images (ROCK64) - by pineadmin - 08-06-2018, 02:30 AM
RE: Linux Images (ROCK64) - by gedas07 - 08-24-2018, 08:22 AM
RE: Linux Images (ROCK64) - by gene83 - 08-06-2018, 06:43 AM
RE: Linux Images (ROCK64) - by boudiicca - 08-06-2018, 08:15 AM
RE: Linux Images (ROCK64) - by ayufan - 08-06-2018, 11:32 AM
RE: Linux Images (ROCK64) - by AkiraSensei - 08-09-2018, 01:47 PM
RE: Linux Images (ROCK64) - by Averell - 09-12-2018, 06:02 AM
RE: Linux Images (ROCK64) - by evilbunny - 09-12-2018, 06:21 AM
RE: Linux Images (ROCK64) - by Averell - 09-26-2018, 05:31 AM
RE: Linux Images (ROCK64) - by evilbunny - 09-26-2018, 06:30 AM
RE: Linux Images (ROCK64) - by Averell - 11-01-2018, 12:47 PM
RE: Linux Images (ROCK64) - by thewonderer - 09-19-2018, 10:16 PM
RE: Linux Images (ROCK64) - by Luke - 09-20-2018, 04:00 AM
RE: Linux Images (ROCK64) - by thewonderer - 09-20-2018, 04:48 PM
RE: Linux Images (ROCK64) - by Averell - 10-17-2018, 07:26 AM
RE: Linux Images (ROCK64) - by Averell - 10-17-2018, 10:22 AM
RE: Linux Images (ROCK64) - by Averell - 10-18-2018, 06:37 AM
RE: Linux Images (ROCK64) - by thewonderer - 11-01-2018, 09:34 PM
RE: Linux Images (ROCK64) - by Averell - 08-18-2019, 12:18 AM
RE: Linux Images (ROCK64) - by kcirap - 08-26-2019, 05:52 PM
RE: Linux Images (ROCK64) - by fire219 - 08-26-2019, 06:11 PM
RE: Linux Images (ROCK64) - by kcirap - 08-26-2019, 09:28 PM
RE: Linux Images (ROCK64) - by kcirap - 08-30-2019, 05:08 PM
RE: Linux Images (ROCK64) - by dpgraham - 01-12-2020, 01:39 PM
RE: Linux Images (ROCK64) - by evilbunny - 01-12-2020, 07:52 PM
RE: Linux Images (ROCK64) - by dpgraham - 01-14-2020, 12:23 PM
RE: Linux Images (ROCK64) - by useful64 - 05-07-2020, 12:01 PM
RE: Linux Images (ROCK64) - by scalextrix - 05-05-2020, 12:22 PM
RE: Linux Images (ROCK64) - by vve1505 - 07-25-2020, 01:57 PM
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 12 17,428 03-07-2026, 11:04 AM
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 585 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 5,012 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 10,968 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 2,813 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 2,924 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 4,109 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  DietPi OS for ROCK64 MichaIng 42 80,886 09-01-2024, 06:43 AM
Last Post: RaymondDay
Smile First Lakka image for Rock64! Luke 47 106,098 09-01-2024, 06:05 AM
  Rock64 v2 - did not work song / audio sqw200zu 2 5,479 03-14-2024, 03:09 AM
