Fedora Running On Pine64!
(07-31-2017, 07:37 PM)pfeerick Wrote:
(07-31-2017, 02:17 PM)Gnx Wrote: you can use several programs, win32diskimager, or etcher. you just use one of those programs to burn the image to the sd card.
pine wiki instructions:
http://wiki.pine64.org/index.php/Main_Pa...2F8.1.2F10
win32diskimager:
https://sourceforge.net/projects/win32diskimager/
Etcher:
https://etcher.io/
Don't think it's quite that easy Gnx... from what I remember of cztian's commentary on the IRC, the fedora image was on a USB drive, and he basically had a minimal image on the SD card, with something deleted, so that uboot skipped to the USB drive to look for the next boot option... hopefully someone can add a simple step by step, or a basic image that can be used. And maybe also a heads up as to if this worked in the end Wink
And please consider linking to Rufus in the future instead of win32diskimager... as win32diskimager has zero verification abilities, so can't tell you if the medium is faulty. Rufus can at least run a check for bad blocks before it writes the image, and is handy have to have around for general formatting needs also.
There is only a uboot image on the SD card, and we can use setenv command to change boot order
Fedora Running On Pine64! - by cztian - 07-20-2017, 10:23 PM
RE: Fedora Running On Pine64! - by tllim - 07-20-2017, 10:45 PM
RE: Fedora Running On Pine64! - by heatfanjohn - 07-29-2017, 09:52 PM
RE: Fedora Running On Pine64! - by Gnx - 07-31-2017, 02:17 PM
RE: Fedora Running On Pine64! - by pfeerick - 07-31-2017, 07:37 PM
RE: Fedora Running On Pine64! - by heatfanjohn - 07-31-2017, 09:58 PM
RE: Fedora Running On Pine64! - by cztian - 08-01-2017, 07:15 AM
RE: Fedora Running On Pine64! - by Gnx - 08-01-2017, 03:38 AM
RE: Fedora Running On Pine64! - by heatfanjohn - 08-02-2017, 07:52 AM
RE: Fedora Running On Pine64! - by Absurd - 08-02-2017, 12:39 PM
RE: Fedora Running On Pine64! - by heatfanjohn - 08-02-2017, 06:33 PM
RE: Fedora Running On Pine64! - by heatfanjohn - 08-02-2017, 10:03 AM
RE: Fedora Running On Pine64! - by Absurd - 08-02-2017, 12:53 PM
RE: Fedora Running On Pine64! - by heatfanjohn - 08-03-2017, 02:21 PM
RE: Fedora Running On Pine64! - by Absurd - 08-04-2017, 06:22 AM
RE: Fedora Running On Pine64! - by heatfanjohn - 08-04-2017, 12:23 PM
RE: Fedora Running On Pine64! - by Absurd - 08-07-2017, 11:44 AM
RE: Fedora Running On Pine64! - by cztian - 08-12-2017, 04:08 AM
RE: Fedora Running On Pine64! - by Absurd - 08-17-2017, 05:55 AM
RE: Fedora Running On Pine64! - by heatfanjohn - 08-18-2017, 06:24 PM
RE: Fedora Running On Pine64! - by Absurd - 08-20-2017, 08:13 AM
RE: Fedora Running On Pine64! - by KrYpToNiTe - 08-20-2017, 07:43 PM
RE: Fedora Running On Pine64! - by cztian - 08-25-2017, 08:08 PM
RE: Fedora Running On Pine64! - by Absurd - 09-05-2017, 01:35 PM
RE: Fedora Running On Pine64! - by joe - 09-09-2017, 08:37 AM
RE: Fedora Running On Pine64! - by cztian - 09-10-2017, 06:46 AM
RE: Fedora Running On Pine64! - by gregjo - 10-26-2017, 05:51 PM
  Fedora 32/CentOS 8 Pine A64+ Images wideawake 2 5,356 10-02-2020, 11:38 AM
Last Post: mathiraj
  Programming languages support under PINE64 baryluk 6 12,067 09-23-2020, 11:46 PM
Last Post: Phillip Bell
  Manjaro arm on pine64+ roel 2 5,784 10-19-2019, 05:13 AM
Last Post: roel
  +PINEBOOK Fedora 30 on Pinebook sdgathman 0 3,319 08-14-2019, 11:41 AM
Last Post: sdgathman
  Volumio for PINE64 Released mikelangeloz 11 24,136 03-22-2019, 09:25 AM
Last Post: llungster
  I2S Audio patches for Pine64+ uploaded to GitHub ramstadt 1 3,962 01-19-2019, 11:31 AM
Last Post: ramstadt
  Pine64: Minimal SDL config Max11 3 5,856 01-04-2019, 03:47 PM
Last Post: Max11
  Fedora 27 on Pine64 gregjo 18 34,575 01-02-2019, 10:42 PM
Last Post: heatfanjohn
  Official build procedure of ayufan pine64 r.tanaka 0 3,066 08-21-2018, 10:54 PM
Last Post: r.tanaka
  DKMS on kernel 3.10.107-pine64 obrienmd 5 8,418 06-21-2018, 05:45 PM
Last Post: evilbunny
