07-21-2017, 02:49 PM
(07-21-2017, 09:29 AM)ayufan Wrote: You may be interested in latest build that improves Mali integration:
- Makes to use mesa-egl if non-sunxidrm is used,
- Uses mali if sunxidrm is used,
- Properly packages libraries and uses ldconfig to configure system,
- Enables EGL backend for Chromium,
- Adds backlight controls.
https://github.com/ayufan-pine64/linux-b.../tag/0.7.5
First I disabled sunxidrm via the script, then updated via the 3 scripts to 0.7.5, and enabled sunxidrm again. After reboot I had a gl-mark2-es score around 95 again, and sound was working. After the next reboot, sound is gone. I think I had that before. Will try later a disable/enable again.
I've the LCD brightness panel applet, which can change the brightness now, when drm enabled, but when I drag it down, screen becomes black, and I can't seem to get brightness back up, even though I do not release pad button..
I also had an update of drm i think on a apt-get upgrade from your repository.
If there's any specific testing I can do, let me know, I am not a developper, but perhaps can do some more testing
Cheers!
