DRAM and GPU clock
(07-11-2017, 07:54 PM)stephen fleming Wrote: The places that I saw that the memory was 1866MHz is in a CNXSoft article announcing the Rock64 a month ago, and the banner for the Rock64 forum:
ROCK64 is a credit card size 4K60P HDR Media Board Computer powered by Rockchip RK3328 Quad-Core ARM Cortex A53 64-Bit Processor and support up to 4GB 1866MHz LPDDR3 memory
The reason why I am interested in specifically what the DRAM and GPU clock, is that I am making a spreadsheet with the specs for the Rock64, Raspberry Pi 3 and Odroid C2. Also one thing that I noticed in the CNXSoft article is that the 40 pin pi-2 connector had analog inputs, but there was no indication on the pin-out documentation for the connector of any pins associated with a ADC that I could see.
We've explained the memory situation to you, and we told you the truth.   Eventually the PC-1866 memory will be used after it stabilizes.  The article is not wrong either -- up to 1866 is allowed;  just ours doesn't have it !!
You can read about the pinouts of the PI-2 and PI P5+ bus at this link.  The gpio(s) are not analogue;  however, I2C and SPI are supported so adding any number of ADC-DAC chips is possible;
DRAM and GPU clock - by stephen fleming - 07-11-2017, 06:08 PM
RE: DRAM and GPU clock - by MarkHaysHarris777 - 07-11-2017, 06:21 PM
RE: DRAM and GPU clock - by xalius - 07-11-2017, 06:24 PM
RE: DRAM and GPU clock - by stephen fleming - 07-11-2017, 07:54 PM
RE: DRAM and GPU clock - by MarkHaysHarris777 - 07-11-2017, 08:14 PM
RE: DRAM and GPU clock - by stephen fleming - 07-11-2017, 08:35 PM
  Rock64 Real Time Clock User 15267 1 2,827 07-03-2020, 06:47 AM
Last Post: t4_4t
  Rock64 v3 with Real Time Clock (RTC), how to verify? Enig123 1 2,737 05-31-2020, 07:31 PM
Last Post: Rocklobster
