WARNING: internal 10|100 PHY requires magjack hardware!
#33
Thanks a lot for all the info, I think they will be very useful to anybody wanting to add the second Ethernet port to Rock64.
I have followed another approach: since I was not able to find locally any 1.8V voltage regulator, I resorted to an LM317L for which I calculated the needed resistors for outputting the needed 1.8V: once I will have the circuit properly working, I will be back to this at a later time, publishing also the relevant schema.
My problem is now in enabling the eth1 device. I am currently using DietPi 6.19.7 with ayufan kernel 4.4.132-1075-rockchip-ayufan-ga83beded8524. I have tried the command
sudo enable_dtoverlay eth1 ethernet@ff550000 okay
but I obtain invariably the following output, and the eth1 port is not made available:
Applying...
/dts-v1/;
       fragment@0 {
               target-path = "/ethernet@ff550000";
               __overlay__ {
                       status="okay";
Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
unapplied <<---- !!!
I tried to do the same with another device, for instance i2c0, and it works perfectly. Am I using the wrong kernel??? What am I missing?
RE: WARNING: internal 10|100 PHY requires magjack hardware! - by WrongWorld - 01-15-2019, 08:09 PM
  Any way to tell the rock64's hardware revision? kittyland 1 4,756 07-01-2021, 09:42 PM
Last Post: evilbunny
  Hardware random number generator? scalextrix 13 22,384 06-04-2018, 02:05 AM
Last Post: scalextrix
  Latest Rock64 board hardware revision Ryan 3 6,820 03-14-2018, 05:42 AM
Last Post: petec
Question How can I use the internal 100M ethernet? gabrielmartinslima 1 3,719 02-12-2018, 02:10 PM
Last Post: dkryder
Information Rock64 SSD internal PNY CS900 240GB w/Pine usb|sata adapter MarkHaysHarris777 1 4,815 09-30-2017, 06:48 AM
Last Post: dkryder
