WARNING: internal 10|100 PHY requires magjack hardware!
#28
(01-09-2019, 01:00 AM)t4_4t Wrote: The supply voltage to this FEPHY-block is 1.8v / 1.0v .
As far as the RK3328 data sheet is not available, everything is guessed.
Perhaps the PHY driver/receiver part is designed for use at 1.8v.
If so, termination to 3.3v is risky.
I am not able to find that voltage regulator Sad
For 1.2V yes, for 2.5V also, but for 1.8V NO, three shops told me already they had none. I am thinking about trying with the 1.2V model, I'll have to recalculate the resistors values. I have also a question regarding the caps for the regulator: why do they have different values? The example schema accompanying the voltage regulator suggest to use the same value for both caps. Why yours are different?
Thanks.
RE: WARNING: internal 10|100 PHY requires magjack hardware! - by WrongWorld - 01-10-2019, 04:36 PM
  Any way to tell the rock64's hardware revision? kittyland 1 2,954 07-01-2021, 09:42 PM
Last Post: evilbunny
  Hardware random number generator? scalextrix 13 15,956 06-04-2018, 02:05 AM
Last Post: scalextrix
  Latest Rock64 board hardware revision Ryan 3 5,218 03-14-2018, 05:42 AM
Last Post: petec
Question How can I use the internal 100M ethernet? gabrielmartinslima 1 2,686 02-12-2018, 02:10 PM
Last Post: dkryder
Information Rock64 SSD internal PNY CS900 240GB w/Pine usb|sata adapter MarkHaysHarris777 1 3,675 09-30-2017, 06:48 AM
Last Post: dkryder
