WARNING: internal 10|100 PHY requires magjack hardware!
http://files.pine64.org/doc/rock64/ROCK6..._Board.pdf
If someone created it according to the circuit diagram above and it worked, please report it.
Initially, this circuit diagram itself would be wrong.
Because, it became to work after adding a terminating resistor.
# ifconfig -a
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
       inet 192.168.0.236  netmask 255.255.255.0  broadcast 192.168.0.255
       inet6 fe80::90bc:baff:fec6:deac  prefixlen 64  scopeid 0x20<link>
       ether 92:bc:ba:c6:de:ac  txqueuelen 1000  (Ethernet)
       RX packets 255001  bytes 385956568 (385.9 MB)
       RX errors 0  dropped 0  overruns 0  frame 0
       TX packets 11313  bytes 748006 (748.0 KB)
       TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
       device interrupt 42
eth1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
       inet 192.168.0.237  netmask 255.255.255.0  broadcast 192.168.0.255
       inet6 fe80::90bc:baff:fec6:decc  prefixlen 64  scopeid 0x20<link>
       ether 92:bc:ba:c6:de:cc  txqueuelen 1000  (Ethernet)
       RX packets 509955  bytes 771910406 (771.9 MB)
       TX packets 163912  bytes 10998013 (10.9 MB)
       device interrupt 43
RE: WARNING: internal 10|100 PHY requires magjack hardware! - by t4_4t - 07-27-2018, 11:41 AM
  Any way to tell the rock64's hardware revision? kittyland 1 6,063 07-01-2021, 09:42 PM
Last Post: evilbunny
  Hardware random number generator? scalextrix 13 24,602 06-04-2018, 02:05 AM
Last Post: scalextrix
  Latest Rock64 board hardware revision Ryan 3 7,226 03-14-2018, 05:42 AM
Last Post: petec
Question How can I use the internal 100M ethernet? gabrielmartinslima 1 4,031 02-12-2018, 02:10 PM
Last Post: dkryder
Information Rock64 SSD internal PNY CS900 240GB w/Pine usb|sata adapter MarkHaysHarris777 1 5,100 09-30-2017, 06:48 AM
Last Post: dkryder
