Does the ROCK64 support CEC over HDMI?
(07-05-2017, 02:53 PM)ayufan Wrote: Yes. It already does work on Android, but controls to support that on Linux are also present: https://github.com/rockchip-linux/kernel...nable&type=. We may need to upgrade libcec to support a new device, but I wonder if exynos compatibility layer would not work OoB.
I can find the cec function in the hdmi settings. but unfortunately they turn off automatically after turning on. I used the cec function under LibreElec Leia of Raybuntu but this operating system is absolutely unstable and does not work as required. for my purposes, only the android of ayufan currently works properly. Thanks a lot for this. the more I would be glad if the cec problem and one or the other bugs could be solved. I also regularly experience a loss of network connection via the RJ45 socket. if I unplug the cable and insert again the connection is immediately available again but unfortunately not constant. I use the regular android 7.1.2 root version.
thanks again for your great work and keep it up. I will test your pre-releases today.
| Messages In This Thread |
RE: Does the ROCK64 support CEC over HDMI? - by geno - 03-17-2018, 04:27 AM
| Possibly Related Threads… |
| Thread |
Author |
Replies |
Views |
Last Post |
Rock64 v3 Tx/RX and GPIO connections for 3dprinter |
MinimumJargon |
2 |
390 |
01-28-2026, 04:04 AM
Last Post: alicesphere
Rock64 - not booting after Armbian update |
helpmerock |
7 |
4,557 |
01-24-2026, 04:44 PM
Last Post: ff255
irradium (based on crux linux) Rock64 riscv64, aarch64 |
mara |
11 |
16,814 |
12-06-2025, 01:32 PM
Xen hypervisor on Rock64 |
tumbleweed |
6 |
10,582 |
11-03-2025, 09:25 AM
Last Post: darkfader
can rock64 4gb ram run entirely on free software? |
heocb |
1 |
2,657 |
01-07-2025, 05:47 AM
Upgrading ancient Rock64 |
timxjr1300 |
1 |
2,777 |
11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
arch rock64 does not boot |
nemnob |
1 |
3,955 |
09-20-2024, 11:18 AM
Last Post: AwU2HBg
DietPi OS for ROCK64 |
MichaIng |
42 |
77,717 |
09-01-2024, 06:43 AM
Last Post: RaymondDay
First Lakka image for Rock64! |
Luke |
47 |
104,117 |
09-01-2024, 06:05 AM
Rock64 v2 - did not work song / audio |
sqw200zu |
2 |
5,282 |
03-14-2024, 03:09 AM
