HDMI overscan problem
I have tried the above commands, but they don't help enough. I am using a Dell 2408WFP monitor at 1920 x 1080. This is a widescreen monitor, will Full HD resolution.
The fbset application installs OK any can be used to change the frame buffer size.
Stopping the lightdm service makes my screen go black (no GUI / Window Manager). I need to reset the PINE before I can do anything else.
Using the above fbset command split my screen into two parts, the the RHS being a duplicate of the LHS. There were two mouse cursors! I think this was caused by the -vxres and -vyres parameters (or possibly -a). Using -xres and -yres on their own seemed to work OK.
Using the command fbset -xres 1280 brought the desktop items back onto the screen (shifting the left edge of the screen to it's proper place). However, the fond size became as little larger, as the screen resolution decreased. I tried to use the -yes option to get the taskbar to appear correctly, but even with -yres 300 the taskbar was still partially off the top of the screen and there was nothing at the bottom of the screen.
Hope this helps.
David Hardingham
HDMI overscan problem - by Terra854 - 03-19-2016, 11:56 AM
RE: HDMI overscan problem - by tllim - 03-19-2016, 12:09 PM
RE: HDMI overscan problem - by ak_hepcat - 04-08-2016, 06:07 PM
RE: HDMI overscan problem - by tllim - 04-09-2016, 11:19 PM
RE: HDMI overscan problem - by spacemonkey - 04-20-2016, 10:57 AM
RE: HDMI overscan problem - by Pine642G - 04-21-2016, 09:00 PM
RE: HDMI overscan problem - by tllim - 04-22-2016, 12:09 AM
RE: HDMI overscan problem - by ryanvade - 04-24-2016, 06:40 PM
RE: HDMI overscan problem - by dhardingham - 04-26-2016, 10:14 AM
RE: HDMI overscan problem - by gdjsky01 - 05-30-2016, 10:12 PM
  pine64 problem reboot ludo77 1 3,123 10-23-2017, 04:47 PM
  problem pine64 when reboot ludo77 2 3,590 10-23-2017, 02:37 AM
Last Post: Luke
  Linux TouchLCD+HDMI sharmayogesh 3 3,923 04-14-2017, 01:23 PM
Last Post: sharmayogesh
  OpenWRT supports ARMv8 - arm64, u-boot problem? rgdonato 4 5,552 03-20-2017, 03:59 PM
Last Post: rgdonato
  Pine64_health.sh problem jl_678 3 5,167 08-26-2016, 06:08 AM
Last Post: pfeerick
  HDMI 1080P Ophir 1 2,665 07-27-2016, 08:17 PM
Last Post: Ghost
  DTS options for HDMI-DVI adapters xalius 0 1,616 07-07-2016, 09:57 AM
Last Post: xalius
  HDMI->DVI Works "solution" Luke 9 13,777 05-04-2016, 12:40 PM
Last Post: Luke
  HDMI Overscan / Underscan Dygaer 1 3,025 04-28-2016, 07:40 AM
Last Post: dhardingham
