A case with active cooling for 1Gb pine64
(06-27-2017, 01:38 AM)ishwest Wrote: In my experience putting the fan inside the case reduces the noise way better than pwm does.
That and getting a larger, slower turning or better balanced fan helps. Wink I went for 50mm fans because I've seen so many of the 20mm and 30mm ones become screaming monsters because of higher RPMs to make up for their smaller size, or just bad bearings/sleeves. I couldn't quite justify a 90mm or 120mm fan this time Wink
(06-27-2017, 01:38 AM)ishwest Wrote: There's a 14% chance that the fan will start at 56°C. Then the probability goes up linearly with CPU/GPU temperature until it hits 100% at 62°C. And symmetrically the probability of the fan stopping goes from 0% to 100% with the temperature dropping from 54°C to  47°C.
I take it the magic is in this statement?
return random.randint(0,101) <= 100 * (higher_temp - high_mid_temp) / (TEMP_ON - high_mid_temp)
I'll have to shell script-ify it and see how it compares to my current setup... very interesting indeed... looks like $RANDOM will have to get a workout! Wink
RE: A case with active cooling for 1Gb pine64 - by pfeerick - 06-28-2017, 12:57 AM
Photo Weatherproof case build ltorsini 11 32,497 11-12-2024, 10:12 PM
Last Post: ltorsini
  Are the Pine64 Acrylic Open Enclosures Stackable? abhinava 5 11,380 09-17-2020, 06:41 AM
Last Post: dabou
Big Grin Super Mario case [NOW WITH UPDATED STL-FILE (April 27.)] Tarjei85 37 74,746 07-23-2020, 05:31 AM
Last Post: devendraraju
  Made a case for the Pine64 with Audio DAC installed kodachrome 1 4,634 11-12-2019, 04:52 AM
Last Post: xalius
  playbox case ribbon cable too short pinoosh 7 14,559 02-22-2019, 03:24 AM
Last Post: GaryFunk
Video 7" LCD wooden framen enclosure for Pine64 *UPDATED WITH killor 12 23,399 10-12-2018, 03:08 PM
  Clear case PIne 64 with VESA100 LIPO , RTC holder, and mini fan holes killor 6 13,431 08-05-2017, 07:15 AM
Last Post: killor
  New Pine 64 Screen Case from C4Labs Dustin_C4Labs 11 22,237 07-18-2017, 10:39 AM
  Lego Case Kiryu 67 105,774 03-30-2017, 11:36 AM
Last Post: Luke
  Acrylic case with Lipo Holder and 2 Tactile push button included killor 9 15,754 10-24-2016, 08:18 AM
Last Post: killor
