A case with active cooling for 1Gb pine64
pfeerick, xalius thanks!
(06-26-2017, 09:47 PM)pfeerick Wrote: … just avoided software PWM as I don't see the benefits in this particular application.
My thoughts exactly!
In my experience putting the fan inside the case reduces the noise way better than pwm does.
Actually I've started writing a soft-pwm daemon but given up on it once I figured it's taking too much effort for smth I don't even need :-)
(06-26-2017, 09:47 PM)pfeerick Wrote: I instead have mine running at (would you look at that!) 55c and cutting out at 38c. I intend to add a little more to it where it keeps running for say a minute once it hits the low end, to minimise on/off oscillation when it does heavy work.
I've used a stochastic approach to this issue :-)
There's a 14% chance that the fan will start at 56°C. Then the probability goes up linearly with CPU/GPU temperature until it hits 100% at 62°C. And symmetrically the probability of the fan stopping goes from 0% to 100% with the temperature dropping from 54°C to  47°C.
Did it on a whim but works surprisingly well for me :-)
RE: A case with active cooling for 1Gb pine64 - by ishwest - 06-27-2017, 01:38 AM
  Are the Pine64 Acrylic Open Enclosures Stackable? abhinava 5 9,558 09-17-2020, 06:41 AM
Last Post: dabou
Big Grin Super Mario case [NOW WITH UPDATED STL-FILE (April 27.)] Tarjei85 37 64,063 07-23-2020, 05:31 AM
Last Post: devendraraju
  Made a case for the Pine64 with Audio DAC installed kodachrome 1 3,951 11-12-2019, 04:52 AM
Last Post: xalius
  playbox case ribbon cable too short pinoosh 7 12,250 02-22-2019, 03:24 AM
Last Post: GaryFunk
Video 7" LCD wooden framen enclosure for Pine64 *UPDATED WITH killor 12 19,741 10-12-2018, 03:08 PM
  Clear case PIne 64 with VESA100 LIPO , RTC holder, and mini fan holes killor 6 11,503 08-05-2017, 07:15 AM
Last Post: killor
  New Pine 64 Screen Case from C4Labs Dustin_C4Labs 11 18,913 07-18-2017, 10:39 AM
  Lego Case Kiryu 67 88,575 03-30-2017, 11:36 AM
Last Post: Luke
  Acrylic case with Lipo Holder and 2 Tactile push button included killor 9 12,993 10-24-2016, 08:18 AM
Last Post: killor
  Pine64 DOA - and they don't care mldavies 4 8,995 10-13-2016, 03:57 AM
