Error formatting MicroSD
#22
(04-06-2016, 05:34 AM)Rhymoore Wrote: Hi,
I had kinda the same problem, when i tried to install / burn an image via phoenix.
I plainly used the micrsoft formatting software (my computer, right click the sd card format (fat32, standard)) and then i was able to burn an image (need to start the phoenix software with admin (right click the exe launch as administrator). It only took the software about 1 minute.
i am using windows 10.
Thanks for this suggestion Rhymoore, it worked perfectly for me! I tried so many things before this and only your workaround was the solution. Its so simple too. Hope others can find this little tip.
Error formatting MicroSD - by Terra854 - 03-17-2016, 08:09 AM
Error formatting MicroSD - by skybadiver - 03-18-2016, 07:19 PM
RE: Error formatting MicroSD - by KryPtAlIvIaN - 03-18-2016, 07:51 PM
Error formatting MicroSD - by skybadiver - 03-19-2016, 08:47 PM
RE: Error formatting MicroSD - by Terra854 - 03-20-2016, 03:02 AM
RE: Error formatting MicroSD - by Andrew2 - 03-20-2016, 03:14 AM
RE: Error formatting MicroSD - by mhump711 - 04-03-2016, 12:07 PM
RE: Error formatting MicroSD - by tllim - 04-03-2016, 02:23 PM
RE: Error formatting MicroSD - by mhump711 - 04-03-2016, 03:24 PM
RE: Error formatting MicroSD - by mhump711 - 04-03-2016, 08:39 PM
RE: Error formatting MicroSD - by Rhymoore - 04-06-2016, 05:34 AM
RE: Error formatting MicroSD - by AnaNova - 03-07-2017, 01:31 AM
RE: Error formatting MicroSD - by rikardo1979 - 04-06-2016, 11:08 PM
RE: Error formatting MicroSD - by yusijs - 04-08-2016, 04:14 AM
RE: Error formatting MicroSD - by rahlquist - 04-08-2016, 07:04 AM
RE: Error formatting MicroSD - by rikardo1979 - 04-10-2016, 05:47 AM
RE: Error formatting MicroSD - by Tarjei85 - 04-10-2016, 06:21 AM
RE: Error formatting MicroSD - by rikardo1979 - 04-10-2016, 06:34 AM
RE: Error formatting MicroSD - by yusijs - 04-08-2016, 05:15 AM
RE: Error formatting MicroSD - by AwkwardEquation - 04-08-2016, 06:36 AM
RE: Error formatting MicroSD - by yusijs - 04-08-2016, 07:01 AM
RE: Error formatting MicroSD - by patrickhwood - 04-14-2016, 10:04 PM
  SD card too small Error loungehound 7 16,555 01-21-2017, 05:37 PM
Last Post: Bluphire
  Netflix (v4.9.5) Error 1018 on Playback evanthor 3 18,941 12-19-2016, 09:24 AM
Last Post: Bluphire
  MicroSD Size mismatch with Image Hbtr 23 40,523 08-31-2016, 09:00 AM
Last Post: montero65
  Change MicroSD card AA666 2 6,086 05-26-2016, 01:20 PM
Last Post: AA666
