RESOLVED - LCD screen not working, HDMI does
(03-29-2017, 06:47 AM)asuras Wrote: Hey
I know there are other threads out there with similar issues and people have managed to fix it, but i have tried everything that i'm aware of and can find but i cant get my LCD to work.
All cables are correctly connected
It's definitely the right image (android LCD - i have used the android 6 LCD and the android 7 )
The power light stays on so it's not that i don't think.
I have plugged it into my tv using the HDMI cable and it works fine.
With both images when plugged into the LCD and the power nothing happens at all no screen flash or anything its just blank. any help would be greatly appreciated.
I'm a bit late in the game in setting up my pine!
if you need any more info please let me know
Strange, Android LCD should work without any tinkering. Make sure you are using one of the images denoted as: If you are using ayufan's build then you'll need to edit uEnv.txt to include the following:
pine64_lcd=on
RE: LCD screen not working, HDMI does - by Luke - 03-29-2017, 06:58 AM
RE: LCD screen not working, HDMI does - by asuras - 03-29-2017, 12:07 PM
RE: LCD screen not working, HDMI does - by Luke - 03-29-2017, 12:30 PM
RE: LCD screen not working, HDMI does - by asuras - 03-29-2017, 12:54 PM
RE: LCD screen not working, HDMI does - by asuras - 03-31-2017, 02:51 PM
RE: LCD screen not working, HDMI does - by Luke - 03-31-2017, 03:33 PM
RE: LCD screen not working, HDMI does - by asuras - 04-01-2017, 10:01 AM
  Ctrl + Shift + Tab not working in Firefox Bolitoglossa 2 4,129 08-21-2020, 04:05 AM
Last Post: Bolitoglossa
  7" LCD Touch Screen Panel IanJames 0 2,066 04-01-2020, 04:40 PM
Last Post: IanJames
  Pine HDMI -> DVI monitor Pineapple 4 7,797 09-10-2019, 11:28 AM
Last Post: Pineapple
  User Screen Black After Changing Power Settings 0b51Gekko 2 4,746 07-03-2019, 07:53 AM
Last Post: 0b51Gekko
  Input not working after a forced shutdown dic1911 1 3,473 12-24-2018, 07:45 PM
  First Boot HDMI/USB problem reefer 1 5,008 11-18-2018, 10:32 PM
  Any success working with OpenCV on the PineA64? Tonny91 0 2,453 10-16-2018, 09:16 PM
Last Post: Tonny91
  Here Is another mini-how-to to install Raspbian:DESKTOP/ETHERNET/HDMI speedro86 4 8,183 04-15-2018, 07:37 AM
Last Post: bunkerWHz
  Rock64 + 7" touch screen naviathan 2 5,030 09-28-2017, 09:01 AM
Last Post: naviathan
  7" Screen - Does it work with Debian abasel 1 3,891 07-26-2017, 05:44 AM
Last Post: pfeerick
