Pine A64 Plus Fails to Boot
(04-10-2017, 10:59 PM)TinkerBear Wrote: Hey Mark, thanks for your help the other night!  You got me unstuck when I was pulling my hair out - much appreciated.
I'm not sure blaming the power supplies is the right answer here.  I'm measuring roughly 0.3A drawn - it's not taxing any of these power supplies, nor the connector.  A quick google says brand-name Micro USB connectors are rated for 1.8A for VCC and GND, and even the crap chinese ones must be good for half that.
I don't think ripple is a problem either - or it'd be causing crashes much more often than just at boot.  My board has run 24 hours without a crash (until I shut it down), once it made it through booting.
So, my working theory is that at some point in the boot, a bunch of hardware is switched on at once, causing a short/sharp sag in the voltage.  (Why it doesn't cause a problem with an HDMI monitor, I don't know, timing issue?)  That's the sort of thing I've seen fixed with a decoupling capacitor, storing a wee bit of energy locally, rather than in the power supply filter caps at the far end of that - probably thin - wire.
Your PI filter undoubtedly works, but I'm not sure it's necessary.  A single capacitor on a connector on the Euler bus is smaller and easier to add than circumventing the entire power input connector and filters.  I think I'll try the biggest ceramic I can find first and see what happens.  Might also see if I can get the o'scope to capture a voltage drop.  But... tomorrow.
hi again,  you're welcome !  ... my pleasure.
... on the connector,  its not a theory;  the engineers at the plant have confirmed that the microUSB connector does not work properly, and they have decided to replace the microUSB with a barrel connector;  the new sopine base boards are now shipping with the new barrel connectors; at some point the pine boards will get this same revision.
marcus
Pine A64 Plus Fails to Boot - by grobbs - 03-27-2017, 01:04 PM
RE: Pine A64 Plus Fails to Boot - by pfeerick - 03-27-2017, 07:52 PM
RE: Pine A64 Plus Fails to Boot - by xalius - 03-28-2017, 05:14 AM
RE: Pine A64 Plus Fails to Boot - by grobbs - 03-28-2017, 01:50 PM
RE: Pine A64 Plus Fails to Boot - by TinkerBear - 04-08-2017, 11:21 PM
RE: Pine A64 Plus Fails to Boot - by TinkerBear - 04-09-2017, 02:08 PM
RE: Pine A64 Plus Fails to Boot - by TinkerBear - 04-09-2017, 03:18 PM
RE: Pine A64 Plus Fails to Boot - by TinkerBear - 04-09-2017, 05:16 PM
RE: Pine A64 Plus Fails to Boot - by pfeerick - 04-09-2017, 07:17 PM
RE: Pine A64 Plus Fails to Boot - by Luke - 04-10-2017, 05:31 AM
RE: Pine A64 Plus Fails to Boot - by TinkerBear - 04-10-2017, 07:42 PM
RE: Pine A64 Plus Fails to Boot - by pfeerick - 04-10-2017, 08:56 PM
RE: Pine A64 Plus Fails to Boot - by TinkerBear - 04-10-2017, 09:18 PM
RE: Pine A64 Plus Fails to Boot - by pfeerick - 04-11-2017, 06:34 PM
RE: Pine A64 Plus Fails to Boot - by pfeerick - 04-13-2017, 02:36 AM
RE: Pine A64 Plus Fails to Boot - by pfeerick - 04-16-2017, 03:02 AM
RE: Pine A64 Plus Fails to Boot - by TinkerBear - 04-10-2017, 10:59 PM
RE: Pine A64 Plus Fails to Boot - by MarkHaysHarris777 - 04-10-2017, 11:09 PM
RE: Pine A64 Plus Fails to Boot - by TinkerBear - 04-11-2017, 05:28 AM
RE: Pine A64 Plus Fails to Boot - by dkryder - 04-11-2017, 05:22 AM
RE: Pine A64 Plus Fails to Boot - by xalius - 04-11-2017, 05:37 AM
RE: Pine A64 Plus Fails to Boot - by dkryder - 04-11-2017, 03:17 PM
RE: Pine A64 Plus Fails to Boot - by Luke - 04-11-2017, 04:32 PM
RE: Pine A64 Plus Fails to Boot - by tommypine - 04-12-2017, 04:47 AM
RE: Pine A64 Plus Fails to Boot - by tommypine - 04-13-2017, 02:56 AM
RE: Pine A64 Plus Fails to Boot - by pfeerick - 04-13-2017, 05:07 AM
RE: Pine A64 Plus Fails to Boot - by tommypine - 04-13-2017, 10:18 AM
RE: Pine A64 Plus Fails to Boot - by TinkerBear - 04-17-2017, 12:52 AM
RE: Pine A64 Plus Fails to Boot - by tommypine - 04-17-2017, 02:45 AM
RE: Pine A64 Plus Fails to Boot - by pfeerick - 04-17-2017, 06:06 PM
  Pine A64+ mainline mipi-dsi Learnincurve 3 6,496 01-12-2021, 07:36 AM
Last Post: Learnincurve
  DietPi OS for PINE A64 MichaIng 0 9,099 12-15-2020, 06:11 AM
Last Post: MichaIng
  Fedora 32/CentOS 8 Pine A64+ Images wideawake 2 5,417 10-02-2020, 11:38 AM
Last Post: mathiraj
  LibreELEC(KODI) for Pine A64 (+) pineadmin 6 15,545 05-02-2020, 10:29 AM
Last Post: aaronmarsh632
  Lakka-nightlies for Pine A64 (and H64) roel 11 19,064 04-23-2020, 12:55 AM
Last Post: roel
  Read DHT22 on Pine A64 ayufan 3 6,524 01-19-2020, 02:51 PM
Last Post: {-DesT-}
  Centos 7 for Pine A64 Luke 2 6,006 05-28-2019, 12:18 AM
Last Post: pineadmin
  NEMS Linux for Pine A64 (+) Luke 1 5,076 05-09-2019, 05:42 PM
  Pine Board using linux stuck during boot sequence ktaragorn 4 8,162 03-30-2019, 06:48 AM
Last Post: ktaragorn
  motionEyeOS (PINE A64(+)) pineadmin 4 11,857 11-09-2018, 03:25 AM
