Pine A64 Plus Fails to Boot
(03-27-2017, 01:04 PM)grobbs Wrote: I'm encountering a really frustrating problem. I'm trying to use my Pine64 in a headless configuration, so failing to boot is a big problem. When I plug into the console, the failure always seems to be at the point of loading "cfg80211". I don't have a wireless module and I don't want any such thing loaded. Any ideas?
[   38.587273] Modules linked in: cfg80211(+)
[   38.596878]
[   38.603529] CPU: 0 PID: 30 Comm: kworker/0:1 Not tainted 3.10.105-0-pine64-longsleep #3
[   38.617457] Workqueue: events start_work
[   38.626878] task: ffffffc039b52f80 ti: ffffffc039b54000 task.ti: ffffffc039b54000
[   38.640301] PC is at __do_softirq+0xb4/0x2d8
[   38.650188] LR is at __do_softirq+0x30/0x2d8
[   38.660029] pc : [<ffffffc0000b5fc4>] lr : [<ffffffc0000b5f40>] pstate: 40000145
[   38.673344] sp : ffffffc039b57910
[   38.682132] x29: ffffffc039b57910 x28: ffffffc000a760c0
[   38.693105] x27: ffffffc000a76000 x26: ffffffc039b57910
Just a stab in the dark here as it is halting around 38 seconds after boot... did you have the ethernet plugged in? If not, you might want to plug it in, or wait for five minutes for it to timeout, as the default config is not set to allow-hotplug but to require a DHCP IP to be discovered on boot.
Pine A64 Plus Fails to Boot - by grobbs - 03-27-2017, 01:04 PM
RE: Pine A64 Plus Fails to Boot - by pfeerick - 03-27-2017, 07:52 PM
RE: Pine A64 Plus Fails to Boot - by xalius - 03-28-2017, 05:14 AM
RE: Pine A64 Plus Fails to Boot - by grobbs - 03-28-2017, 01:50 PM
RE: Pine A64 Plus Fails to Boot - by TinkerBear - 04-08-2017, 11:21 PM
RE: Pine A64 Plus Fails to Boot - by TinkerBear - 04-09-2017, 02:08 PM
RE: Pine A64 Plus Fails to Boot - by TinkerBear - 04-09-2017, 03:18 PM
RE: Pine A64 Plus Fails to Boot - by TinkerBear - 04-09-2017, 05:16 PM
RE: Pine A64 Plus Fails to Boot - by pfeerick - 04-09-2017, 07:17 PM
RE: Pine A64 Plus Fails to Boot - by Luke - 04-10-2017, 05:31 AM
RE: Pine A64 Plus Fails to Boot - by TinkerBear - 04-10-2017, 07:42 PM
RE: Pine A64 Plus Fails to Boot - by pfeerick - 04-10-2017, 08:56 PM
RE: Pine A64 Plus Fails to Boot - by TinkerBear - 04-10-2017, 09:18 PM
RE: Pine A64 Plus Fails to Boot - by pfeerick - 04-11-2017, 06:34 PM
RE: Pine A64 Plus Fails to Boot - by pfeerick - 04-13-2017, 02:36 AM
RE: Pine A64 Plus Fails to Boot - by pfeerick - 04-16-2017, 03:02 AM
RE: Pine A64 Plus Fails to Boot - by TinkerBear - 04-10-2017, 10:59 PM
RE: Pine A64 Plus Fails to Boot - by TinkerBear - 04-11-2017, 05:28 AM
RE: Pine A64 Plus Fails to Boot - by dkryder - 04-11-2017, 05:22 AM
RE: Pine A64 Plus Fails to Boot - by xalius - 04-11-2017, 05:37 AM
RE: Pine A64 Plus Fails to Boot - by dkryder - 04-11-2017, 03:17 PM
RE: Pine A64 Plus Fails to Boot - by Luke - 04-11-2017, 04:32 PM
RE: Pine A64 Plus Fails to Boot - by tommypine - 04-12-2017, 04:47 AM
RE: Pine A64 Plus Fails to Boot - by tommypine - 04-13-2017, 02:56 AM
RE: Pine A64 Plus Fails to Boot - by pfeerick - 04-13-2017, 05:07 AM
RE: Pine A64 Plus Fails to Boot - by tommypine - 04-13-2017, 10:18 AM
RE: Pine A64 Plus Fails to Boot - by TinkerBear - 04-17-2017, 12:52 AM
RE: Pine A64 Plus Fails to Boot - by tommypine - 04-17-2017, 02:45 AM
RE: Pine A64 Plus Fails to Boot - by pfeerick - 04-17-2017, 06:06 PM
  Pine A64+ mainline mipi-dsi Learnincurve 3 6,555 01-12-2021, 07:36 AM
Last Post: Learnincurve
  DietPi OS for PINE A64 MichaIng 0 9,143 12-15-2020, 06:11 AM
Last Post: MichaIng
  Fedora 32/CentOS 8 Pine A64+ Images wideawake 2 5,459 10-02-2020, 11:38 AM
Last Post: mathiraj
  LibreELEC(KODI) for Pine A64 (+) pineadmin 6 15,675 05-02-2020, 10:29 AM
Last Post: aaronmarsh632
  Lakka-nightlies for Pine A64 (and H64) roel 11 19,240 04-23-2020, 12:55 AM
Last Post: roel
  Read DHT22 on Pine A64 ayufan 3 6,571 01-19-2020, 02:51 PM
Last Post: {-DesT-}
  Centos 7 for Pine A64 Luke 2 6,053 05-28-2019, 12:18 AM
Last Post: pineadmin
  NEMS Linux for Pine A64 (+) Luke 1 5,119 05-09-2019, 05:42 PM
  Pine Board using linux stuck during boot sequence ktaragorn 4 8,222 03-30-2019, 06:48 AM
Last Post: ktaragorn
  motionEyeOS (PINE A64(+)) pineadmin 4 11,940 11-09-2018, 03:25 AM
