use uvc as primary camera
(03-20-2017, 04:04 PM)mathiraj Wrote: Thanks for all your replies.
<snip>
su
chown system.camera /dev/video0
chmod 660 /dev/video0
cabling will not buy you anything, because the pine board has no ID pin that can be used to determine OTG or not.  And, if we're talking linux, at least, there is no OTG controller anyways.
If the pine recognizes the camera, there will be a device for it...  the trick will be to point the app at the relevant device  ( for instance  /dev/video0 )  and then make sure that the user is in the right group for the device, and|or that the permissions are correct.
use uvc as primary camera - by mathiraj - 03-19-2017, 08:27 PM
RE: use uvc as primary camera - by dkryder - 03-19-2017, 11:49 PM
RE: use uvc as primary camera - by pfeerick - 03-20-2017, 05:49 AM
RE: use uvc as primary camera - by pfeerick - 03-20-2017, 08:00 PM
RE: use uvc as primary camera - by dkryder - 03-20-2017, 05:57 AM
RE: use uvc as primary camera - by mathiraj - 03-20-2017, 04:04 PM
RE: use uvc as primary camera - by MarkHaysHarris777 - 03-20-2017, 04:13 PM
RE: use uvc as primary camera - by dkryder - 03-20-2017, 09:20 PM
RE: use uvc as primary camera - by mathiraj - 03-22-2017, 07:35 AM
RE: use uvc as primary camera - by dkryder - 03-22-2017, 04:28 PM
  Android USB camera support - Android 7.0 mikey0000 24 52,578 08-27-2018, 08:39 PM
Last Post: lee
  Camera Support Thru Android devildog125 17 29,001 12-04-2016, 09:42 AM
Last Post: kenjiru
  UVC Camera support mikey0000 6 12,300 09-09-2016, 01:49 PM
Last Post: mikey0000
  Camera streaming to TV over long distance CanadianIceTech 6 14,814 08-03-2016, 02:15 AM
Last Post: RangeR
Music RTC and Camera modules g_t_j 2 6,252 05-26-2016, 02:42 PM
Last Post: g_t_j
  Audio from Headphone Jack and Camera Issue cybernak 1 4,804 05-23-2016, 11:02 AM
Question Android + Camera Peripheral T_ech 4 9,571 01-29-2016, 10:01 PM
Last Post: modsbyus
