Accelerated H.264 and HEVC video decoding with Cedrus
#24
If you are on ubuntu image, then probably use longsleep packages. Otherwise:
Before you start you should have installed gcc, gnumake, autoconf and other development tools.
You will also need pixman header files and shared library installed. As well thedevelopment headers and shared library for vdpau. In debian and ubuntu you can install that using :
sudo apt-get install libvdpau-dev
Then
git clone https://github.com/linux-sunxi/libump.git
cd libump
./configure
make
sudo make install
git clone https://github.com/ssvb/xf86-video-fbturbo.git
cd xf86-video-fbturbo/
./configure --prefix=/usr
make
sudo make install
git clone https://github.com/linux-sunxi/libcedrus.git
cd libcedrus
make
sudo make install
git clone https://github.com/linux-sunxi/libvdpau-sunxi.git
cd libvdpau-sunxi
make
sudo make install
This is my /etc/X11/xorg.conf file:
Section "Device"
Identifier "Allwinner A10/A13 FBDEV"
Driver "fbturbo"
Option "fbdev" "/dev/fb0"
Option "SwapbuffersWait" "true"
EndSection
After that restart x server, or just reboot, and use the mplayer script or flags mentioned earlier in the thread. I was using
VDPAU_DRIVER=sunxi /usr/bin/mplayer -vo vdpau -vc ffmpeg12vdpau,ffh264vdpau,ffhevcvdpau, some_file.avi
for playback.
RE: Accelerated H.264 and HEVC video decoding with Cedrus - by baryluk - 05-01-2016, 04:25 PM
  Video wall? monty1 2 6,343 04-12-2017, 04:34 PM
Last Post: monty1
  pine64 accelerated jpeg decoding jacklau 1 5,397 01-12-2017, 01:12 AM
Last Post: Trizna
  Pine64 accelerated H.264 encoding hngjms 7 16,488 10-18-2016, 03:15 AM
Last Post: pfeerick
  The sunxi transform module is very slow, how to do video rotation? jacklau 0 3,274 09-19-2016, 12:24 AM
Last Post: jacklau
  Video encoding h.265/HEVC tomaThoma 1 7,429 07-02-2016, 11:35 PM
  Question about video acceleration BringItOn 10 20,520 06-23-2016, 10:33 AM
Last Post: ssvb
  Linux accelerated graphics nomadewolf 1 5,721 12-29-2015, 11:26 PM
