Rotate Display
I am pretty sure you can rotate the X framebuffer just by setting the rotate option in your X.org config file (/etc/X11/xorg.conf)
From the manual page:
Option "Rotate"
Enable rotation of the display. The supported values are "CW" (clockwise,
90 degrees), "UD" (upside down, 180 degrees) and "CCW" (counter clockwise,
270 degrees). Implies use of the shadow framebuffer layer.   Default: off.
so if you add something like
Option "rotate" "CW"
it should rotate the X screen.
Rotate Display - by boyatomic - 03-03-2017, 05:01 PM
RE: Rotate Display - by xalius - 03-03-2017, 05:23 PM
RE: Rotate Display - by Kiwiboyus - 03-07-2017, 06:47 PM
Question Ultrawide Display for Ubuntu Mate DE dudeytsang 1 6,561 01-01-2017, 07:26 AM
Last Post: CaptainZalo
  Display resolutions? Sailing_Nut 9 16,612 07-13-2016, 01:21 PM
Last Post: Newfies
