Real-time linux kernel
(03-07-2016, 04:16 AM)umiddelb Wrote:
(03-07-2016, 03:29 AM)Artyom Wrote: @umiddelb
Can you tell me, What is the difference between BSP kernel and mainline kernel? What i must do with mainline kernel to get BSP kernel?
The BSP (= Board Support Package) kernel contains patches provided by Allwinner to make the stock Linux kernel run on their SoC. Some of theses patches may interfere with the RT patches.
You can download the mainline 3.10.65 kernel here and run diffs against the BSP kernel for the files indicated above.
Then you need to identify the sections affected by the RT patch in the BSP kernel or run the patch against the mainline sources and compare the files mentioned above before and after applying the RT patch with their BSP kernel counterpart.
Part in BSP kernel which swears RT patch:
patching file arch/arm/mm/fault.c
Hunk #1 FAILED at 277.
1 out of 1 hunk FAILED -- saving rejects to file arch/arm/mm/fault.c.rej
patching file drivers/misc/Makefile
Hunk #1 FAILED at 53.
1 out of 1 hunk FAILED -- saving rejects to file drivers/misc/Makefile.rej
patching file kernel/fork.c
Hunk #2 FAILED at 230.
1 out of 9 hunks FAILED -- saving rejects to file kernel/fork.c.rej
patching file kernel/hrtimer.c
Hunk #1 FAILED at 47.
1 out of 31 hunks FAILED -- saving rejects to file kernel/hrtimer.c.rej
patching file kernel/sched/core.c
Hunk #29 FAILED at 4038.
Hunk #45 FAILED at 7450.
2 out of 46 hunks FAILED -- saving rejects to file kernel/sched/core.c.rej
patching file kernel/watchdog.c
Hunk #2 FAILED at 241.
1 out of 3 hunks FAILED -- saving rejects to file kernel/watchdog.c.rej
patching file mm/page_alloc.c
Hunk #18 FAILED at 5540.
1 out of 21 hunks FAILED -- saving rejects to file mm/page_alloc.c.rej
Real-time linux kernel - by Artyom - 03-02-2016, 09:54 PM
RE: Real-time linux kernel - by Artyom - 03-06-2016, 02:23 AM
RE: Real-time linux kernel - by umiddelb - 03-06-2016, 03:28 PM
RE: Real-time linux kernel - by Artyom - 03-07-2016, 12:47 AM
RE: Real-time linux kernel - by umiddelb - 03-07-2016, 01:48 AM
RE: Real-time linux kernel - by Artyom - 03-07-2016, 02:07 AM
RE: Real-time linux kernel - by Artyom - 03-07-2016, 03:29 AM
RE: Real-time linux kernel - by umiddelb - 03-07-2016, 04:16 AM
RE: Real-time linux kernel - by Artyom - 03-07-2016, 05:29 AM
RE: Real-time linux kernel - by umiddelb - 03-07-2016, 11:24 AM
RE: Real-time linux kernel - by Artyom - 03-08-2016, 10:18 AM
RE: Real-time linux kernel - by Artyom - 03-09-2016, 01:44 AM
RE: Real-time linux kernel - by umiddelb - 03-10-2016, 05:01 AM
RE: Real-time linux kernel - by Artyom - 03-10-2016, 05:24 AM
RE: Real-time linux kernel - by umiddelb - 03-10-2016, 06:31 AM
RE: Real-time linux kernel - by Artyom - 03-10-2016, 07:03 AM
RE: Real-time linux kernel - by umiddelb - 03-10-2016, 02:04 PM
RE: Real-time linux kernel - by Artyom - 03-10-2016, 10:43 PM
RE: Real-time linux kernel - by Artyom - 03-12-2016, 02:43 AM
RE: Real-time linux kernel - by Artyom - 03-28-2016, 08:54 AM
RE: Real-time linux kernel - by umiddelb - 04-14-2016, 04:03 PM
RE: Real-time linux kernel - by Artyom - 04-17-2016, 11:23 PM
RE: Real-time linux kernel - by umiddelb - 05-08-2016, 02:47 PM
RE: Real-time linux kernel - by Artyom - 04-05-2016, 10:57 PM
RE: Real-time linux kernel - by tllim - 04-06-2016, 04:52 PM
RE: Real-time linux kernel - by Artyom - 04-07-2016, 12:03 AM
RE: Real-time linux kernel - by tllim - 04-07-2016, 11:17 AM
RE: Real-time linux kernel - by Artyom - 04-07-2016, 11:49 PM
RE: Real-time linux kernel - by Artyom - 05-09-2016, 03:21 AM
RE: Real-time linux kernel - by Artyom - 05-29-2016, 02:35 AM
RE: Real-time linux kernel - by umiddelb - 06-09-2016, 12:22 AM
RE: Real-time linux kernel - by Artyom - 06-09-2016, 02:08 AM
RE: Real-time linux kernel - by Artyom - 06-09-2016, 07:49 AM
RE: Real-time linux kernel - by tllim - 06-09-2016, 07:30 PM
RE: Real-time linux kernel - by Artyom - 06-09-2016, 09:36 PM
RE: Real-time linux kernel - by umiddelb - 02-08-2017, 02:33 AM
RE: Real-time linux kernel - by tllim - 02-12-2017, 10:11 PM
RE: Real-time linux kernel - by schooner - 02-20-2017, 06:39 AM
RE: Real-time linux kernel - by Learnincurve - 02-08-2017, 03:06 AM
RE: Real-time linux kernel - by umiddelb - 02-08-2017, 03:41 AM
RE: Real-time linux kernel - by Learnincurve - 02-09-2017, 01:02 AM
RE: Real-time linux kernel - by umiddelb - 02-20-2017, 02:44 PM
RE: Real-time linux kernel - by schooner - 02-21-2017, 05:16 AM
RE: Real-time linux kernel - by schooner - 02-21-2017, 08:45 AM
RE: Real-time linux kernel - by dikov - 03-07-2017, 11:49 PM
RE: Real-time linux kernel - by zzwpine - 09-11-2018, 01:08 AM
  NEMS Linux 1.5 Released for A64/A64+, A64-LTS/SOPine, Rock64, RockPro64 (NAGIOS) Baldnerd 4 14,327 03-28-2020, 06:20 PM
Last Post: ty1911
  PineA64+: Audio in 5.0 Kernel puzzles 6 13,668 11-13-2019, 09:41 AM
Last Post: roel
  Howto run Linux with resolution other than 1080p longsleep 28 82,914 06-13-2019, 01:53 AM
Last Post: Nilda
  NEMS Linux for Pine A64 (+) Luke 1 7,998 05-09-2019, 05:42 PM
Last Post: pineadmin
  Pine Board using linux stuck during boot sequence ktaragorn 4 12,504 03-30-2019, 06:48 AM
Last Post: ktaragorn
  Gentoo Linux test image xalius 23 61,877 01-28-2019, 11:05 PM
Last Post: necrose99
  Rockpro64 NFS root mount (kernel 4.20) - ethernet help? tenspd137 0 4,029 12-06-2018, 01:14 AM
Last Post: tenspd137
  NVMe and new kernel bjbb17 0 3,608 09-25-2018, 03:39 PM
Last Post: bjbb17
  DKMS on kernel 3.10.107-pine64 obrienmd 5 12,071 06-21-2018, 05:45 PM
Last Post: evilbunny
  linux distribution hazerty 3 8,615 04-01-2018, 02:48 PM
Last Post: dkryder
