Real-time linux kernel
#41
(02-08-2017, 02:33 AM)umiddelb Wrote: Hi @all,
since we have a more or less working 4.9 mainline kernel, I was able to apply the latest PREEMPT_RT patches against 4.9.6.
You will find the kernel sources here and a ready to extract kernel image here. If you want to modify some of the kernel configuration parameters, I can give you some advice how to do this and how to build a kernel on your own Pine64.
Cheers
Uli
Hi
I think I need some guidance as to where the files need to go and in what name.
I have been trying to substitute for files already in /boot
Image replaces /boot/pine64/Image  (that should be OK)
sun50i-a64-pine64-plus.dtb replaces /boot/pine64/sun50i-a64-pine64-plus.dtb  (why is it so small compared to the original? 9K v 69K)
Initrd is renamed /boot/initrd.img  (Should this now be called Initrd ?  Should it be in the same dir as the Image?)
Either using your files or building my own, boot fails and nothing written in kern.log etc.
Close but so far away at present
Looking at stuff on another forum, looks like everything has changed and the kernel.d dir goes into /boot as it is
That didn't work either.
regards
Real-time linux kernel - by Artyom - 03-02-2016, 09:54 PM
RE: Real-time linux kernel - by Artyom - 03-06-2016, 02:23 AM
RE: Real-time linux kernel - by umiddelb - 03-06-2016, 03:28 PM
RE: Real-time linux kernel - by Artyom - 03-07-2016, 12:47 AM
RE: Real-time linux kernel - by umiddelb - 03-07-2016, 01:48 AM
RE: Real-time linux kernel - by Artyom - 03-07-2016, 02:07 AM
RE: Real-time linux kernel - by Artyom - 03-07-2016, 03:29 AM
RE: Real-time linux kernel - by umiddelb - 03-07-2016, 04:16 AM
RE: Real-time linux kernel - by Artyom - 03-07-2016, 05:29 AM
RE: Real-time linux kernel - by umiddelb - 03-07-2016, 11:24 AM
RE: Real-time linux kernel - by Artyom - 03-08-2016, 10:18 AM
RE: Real-time linux kernel - by Artyom - 03-09-2016, 01:44 AM
RE: Real-time linux kernel - by umiddelb - 03-10-2016, 05:01 AM
RE: Real-time linux kernel - by Artyom - 03-10-2016, 05:24 AM
RE: Real-time linux kernel - by umiddelb - 03-10-2016, 06:31 AM
RE: Real-time linux kernel - by Artyom - 03-10-2016, 07:03 AM
RE: Real-time linux kernel - by umiddelb - 03-10-2016, 02:04 PM
RE: Real-time linux kernel - by Artyom - 03-10-2016, 10:43 PM
RE: Real-time linux kernel - by Artyom - 03-12-2016, 02:43 AM
RE: Real-time linux kernel - by Artyom - 03-28-2016, 08:54 AM
RE: Real-time linux kernel - by umiddelb - 04-14-2016, 04:03 PM
RE: Real-time linux kernel - by Artyom - 04-17-2016, 11:23 PM
RE: Real-time linux kernel - by umiddelb - 05-08-2016, 02:47 PM
RE: Real-time linux kernel - by Artyom - 04-05-2016, 10:57 PM
RE: Real-time linux kernel - by tllim - 04-06-2016, 04:52 PM
RE: Real-time linux kernel - by Artyom - 04-07-2016, 12:03 AM
RE: Real-time linux kernel - by tllim - 04-07-2016, 11:17 AM
RE: Real-time linux kernel - by Artyom - 04-07-2016, 11:49 PM
RE: Real-time linux kernel - by Artyom - 05-09-2016, 03:21 AM
RE: Real-time linux kernel - by Artyom - 05-29-2016, 02:35 AM
RE: Real-time linux kernel - by umiddelb - 06-09-2016, 12:22 AM
RE: Real-time linux kernel - by Artyom - 06-09-2016, 02:08 AM
RE: Real-time linux kernel - by Artyom - 06-09-2016, 07:49 AM
RE: Real-time linux kernel - by tllim - 06-09-2016, 07:30 PM
RE: Real-time linux kernel - by Artyom - 06-09-2016, 09:36 PM
RE: Real-time linux kernel - by umiddelb - 02-08-2017, 02:33 AM
RE: Real-time linux kernel - by tllim - 02-12-2017, 10:11 PM
RE: Real-time linux kernel - by schooner - 02-20-2017, 06:39 AM
RE: Real-time linux kernel - by Learnincurve - 02-08-2017, 03:06 AM
RE: Real-time linux kernel - by umiddelb - 02-08-2017, 03:41 AM
RE: Real-time linux kernel - by Learnincurve - 02-09-2017, 01:02 AM
RE: Real-time linux kernel - by umiddelb - 02-20-2017, 02:44 PM
RE: Real-time linux kernel - by schooner - 02-21-2017, 05:16 AM
RE: Real-time linux kernel - by schooner - 02-21-2017, 08:45 AM
RE: Real-time linux kernel - by dikov - 03-07-2017, 11:49 PM
RE: Real-time linux kernel - by zzwpine - 09-11-2018, 01:08 AM
  NEMS Linux 1.5 Released for A64/A64+, A64-LTS/SOPine, Rock64, RockPro64 (NAGIOS) Baldnerd 4 9,079 03-28-2020, 06:20 PM
Last Post: ty1911
  PineA64+: Audio in 5.0 Kernel puzzles 6 8,786 11-13-2019, 09:41 AM
Last Post: roel
  Howto run Linux with resolution other than 1080p longsleep 28 65,605 06-13-2019, 01:53 AM
Last Post: Nilda
  NEMS Linux for Pine A64 (+) Luke 1 5,020 05-09-2019, 05:42 PM
Last Post: pineadmin
  Pine Board using linux stuck during boot sequence ktaragorn 4 8,044 03-30-2019, 06:48 AM
Last Post: ktaragorn
  Gentoo Linux test image xalius 23 47,880 01-28-2019, 11:05 PM
Last Post: necrose99
  Rockpro64 NFS root mount (kernel 4.20) - ethernet help? tenspd137 0 2,874 12-06-2018, 01:14 AM
Last Post: tenspd137
  NVMe and new kernel bjbb17 0 2,568 09-25-2018, 03:39 PM
Last Post: bjbb17
  DKMS on kernel 3.10.107-pine64 obrienmd 5 8,426 06-21-2018, 05:45 PM
Last Post: evilbunny
  linux distribution hazerty 3 6,003 04-01-2018, 02:48 PM
Last Post: dkryder
