Real-time linux kernel
#37
I'm wanting to build a rt system for digital audio (squeezebox) using a pine64+ (2GB) running Armbian base system.
I've been trying to apply the https://www.kernel.org/pub/linux/kernel/...s/rt/3.10/
patch-3.10.104-rt117 patch set on the Armbian 3.10.104 source tree, following the procedure outlined in the developer guide.
https://docs.armbian.com/Developer-Guide...eparation/
The patches are applied successfully, but I am facing a number of problems with the build.
There were failures in various IP tunnelling modules, which I have simply removed from the config, as I don't need them, but now I'm struggling with:
MODPOST vmlinux.o        │
 │ WARNING: modpost: Found 2 section mismatch(es).        │
 │ To see full details build your kernel with:        │
 │ 'make CONFIG_DEBUG_SECTION_MISMATCH=y'        │
 │   GEN     .version        │
 │   CHK     include/generated/compile.h        │
 │   UPD     include/generated/compile.h        │
 │   CC      init/version.o        │
 │   LD      init/built-in.o        │
 │ drivers/built-in.o: In function `mbus_pmu_remove':        │
 │ arisc_dram_crc.c:(.text+0x1d38): undefined reference to `hwmon_device_unregister'        │
 │ arisc_dram_crc.c:(.text+0x1d38): relocation truncated to fit: R_AARCH64_CALL26 against undefined symbol `hwmon_device_unregister'                │
 │ drivers/built-in.o: In function `mbus_pmu_probe':
Can anyone suggest how to fix it?
I want to stay with 3.10.104 as vanilla doesn't support the LCD interface (which I need for the touch screen).
BR.
--Marius--
Real-time linux kernel - by Artyom - 03-02-2016, 09:54 PM
RE: Real-time linux kernel - by Artyom - 03-06-2016, 02:23 AM
RE: Real-time linux kernel - by umiddelb - 03-06-2016, 03:28 PM
RE: Real-time linux kernel - by Artyom - 03-07-2016, 12:47 AM
RE: Real-time linux kernel - by umiddelb - 03-07-2016, 01:48 AM
RE: Real-time linux kernel - by Artyom - 03-07-2016, 02:07 AM
RE: Real-time linux kernel - by Artyom - 03-07-2016, 03:29 AM
RE: Real-time linux kernel - by umiddelb - 03-07-2016, 04:16 AM
RE: Real-time linux kernel - by Artyom - 03-07-2016, 05:29 AM
RE: Real-time linux kernel - by umiddelb - 03-07-2016, 11:24 AM
RE: Real-time linux kernel - by Artyom - 03-08-2016, 10:18 AM
RE: Real-time linux kernel - by Artyom - 03-09-2016, 01:44 AM
RE: Real-time linux kernel - by umiddelb - 03-10-2016, 05:01 AM
RE: Real-time linux kernel - by Artyom - 03-10-2016, 05:24 AM
RE: Real-time linux kernel - by umiddelb - 03-10-2016, 06:31 AM
RE: Real-time linux kernel - by Artyom - 03-10-2016, 07:03 AM
RE: Real-time linux kernel - by umiddelb - 03-10-2016, 02:04 PM
RE: Real-time linux kernel - by Artyom - 03-10-2016, 10:43 PM
RE: Real-time linux kernel - by Artyom - 03-12-2016, 02:43 AM
RE: Real-time linux kernel - by Artyom - 03-28-2016, 08:54 AM
RE: Real-time linux kernel - by umiddelb - 04-14-2016, 04:03 PM
RE: Real-time linux kernel - by Artyom - 04-17-2016, 11:23 PM
RE: Real-time linux kernel - by umiddelb - 05-08-2016, 02:47 PM
RE: Real-time linux kernel - by Artyom - 04-05-2016, 10:57 PM
RE: Real-time linux kernel - by tllim - 04-06-2016, 04:52 PM
RE: Real-time linux kernel - by Artyom - 04-07-2016, 12:03 AM
RE: Real-time linux kernel - by tllim - 04-07-2016, 11:17 AM
RE: Real-time linux kernel - by Artyom - 04-07-2016, 11:49 PM
RE: Real-time linux kernel - by Artyom - 05-09-2016, 03:21 AM
RE: Real-time linux kernel - by Artyom - 05-29-2016, 02:35 AM
RE: Real-time linux kernel - by umiddelb - 06-09-2016, 12:22 AM
RE: Real-time linux kernel - by Artyom - 06-09-2016, 02:08 AM
RE: Real-time linux kernel - by Artyom - 06-09-2016, 07:49 AM
RE: Real-time linux kernel - by tllim - 06-09-2016, 07:30 PM
RE: Real-time linux kernel - by Artyom - 06-09-2016, 09:36 PM
RE: Real-time linux kernel - by umiddelb - 02-08-2017, 02:33 AM
RE: Real-time linux kernel - by tllim - 02-12-2017, 10:11 PM
RE: Real-time linux kernel - by schooner - 02-20-2017, 06:39 AM
RE: Real-time linux kernel - by Learnincurve - 02-08-2017, 03:06 AM
RE: Real-time linux kernel - by umiddelb - 02-08-2017, 03:41 AM
RE: Real-time linux kernel - by Learnincurve - 02-09-2017, 01:02 AM
RE: Real-time linux kernel - by umiddelb - 02-20-2017, 02:44 PM
RE: Real-time linux kernel - by schooner - 02-21-2017, 05:16 AM
RE: Real-time linux kernel - by schooner - 02-21-2017, 08:45 AM
RE: Real-time linux kernel - by dikov - 03-07-2017, 11:49 PM
RE: Real-time linux kernel - by zzwpine - 09-11-2018, 01:08 AM
  NEMS Linux 1.5 Released for A64/A64+, A64-LTS/SOPine, Rock64, RockPro64 (NAGIOS) Baldnerd 4 14,327 03-28-2020, 06:20 PM
Last Post: ty1911
  PineA64+: Audio in 5.0 Kernel puzzles 6 13,668 11-13-2019, 09:41 AM
Last Post: roel
  Howto run Linux with resolution other than 1080p longsleep 28 82,892 06-13-2019, 01:53 AM
Last Post: Nilda
  NEMS Linux for Pine A64 (+) Luke 1 7,998 05-09-2019, 05:42 PM
Last Post: pineadmin
  Pine Board using linux stuck during boot sequence ktaragorn 4 12,504 03-30-2019, 06:48 AM
Last Post: ktaragorn
  Gentoo Linux test image xalius 23 61,877 01-28-2019, 11:05 PM
Last Post: necrose99
  Rockpro64 NFS root mount (kernel 4.20) - ethernet help? tenspd137 0 4,029 12-06-2018, 01:14 AM
Last Post: tenspd137
  NVMe and new kernel bjbb17 0 3,608 09-25-2018, 03:39 PM
Last Post: bjbb17
  DKMS on kernel 3.10.107-pine64 obrienmd 5 12,071 06-21-2018, 05:45 PM
Last Post: evilbunny
  linux distribution hazerty 3 8,615 04-01-2018, 02:48 PM
Last Post: dkryder
