Pine 64 benchmarks
#42
Final run using the same board as used for the heatsink tests now with heatsink and fan together and 1344 MHz unlocked again: http://openbenchmarking.org/result/16031...603114GA85
The benchmark scores are rather irrelevant (at least if you want to compare different boards -- testing different thermal settings in an active benchmarking approach just allowed us to improve performance settings for Pine64 and to identify most if not all benchmarks used as insufficient)
But at least I could verify that the board runs again at these higher clockspeeds so I've to search for the cause of the shutdowns that happened this afternoon somewhere else (will use the 2nd Pine64+ without heatsink on the PMIC to torture with heavy switching between voltages). And I could also verify that using equipment for $3 the A64 is able to run with light workloads constantly at 1344MHz (two times throttling down to 1200MHz for a moment):
[Image: Pine64_Plus_1344MHz.png]
Since the Phoronix test suite uses extremely unoptimised code (and some of the tests run single threaded and scores will be adjusted by the count of CPU cores afterward -- what a joke) the workload is rather light. Using software that makes heavy use of NEON for example and with my cheap heatsink and fan I'm not able to exceed 1008 MHz (eg. using cpuburn-a53).
Now time to drop the Phoronix stuff and start to further optimise settings with real benchmarks like https://github.com/pooler/cpuminer for example Smile
Pine 64 benchmarks - by patrickhwood - 03-02-2016, 12:11 AM
RE: Pine 64 benchmarks - by nomadewolf - 03-05-2016, 02:04 PM
RE: Pine 64 benchmarks - by patrickhwood - 03-05-2016, 03:10 PM
RE: Pine 64 benchmarks - by janjwerner - 03-06-2016, 11:16 AM
RE: Pine 64 benchmarks - by tllim - 03-06-2016, 11:30 AM
RE: Pine 64 benchmarks - by patrickhwood - 03-06-2016, 11:54 AM
RE: Pine 64 benchmarks - by janjwerner - 03-06-2016, 12:05 PM
RE: Pine 64 benchmarks - by janjwerner - 03-06-2016, 01:41 PM
RE: Pine 64 benchmarks - by longsleep - 03-06-2016, 03:06 PM
RE: Pine 64 benchmarks - by janjwerner - 03-06-2016, 08:04 PM
RE: Pine 64 benchmarks - by Andrew2 - 03-07-2016, 11:30 AM
RE: Pine 64 benchmarks - by longsleep - 03-07-2016, 12:49 AM
RE: Pine 64 benchmarks - by janjwerner - 03-07-2016, 07:54 AM
RE: Pine 64 benchmarks - by longsleep - 03-07-2016, 12:43 PM
RE: Pine 64 benchmarks - by Andrew2 - 03-07-2016, 12:59 PM
RE: Pine 64 benchmarks - by janjwerner - 03-07-2016, 01:34 PM
RE: Pine 64 benchmarks - by longsleep - 03-07-2016, 01:40 PM
RE: Pine 64 benchmarks - by Andrew2 - 03-07-2016, 02:03 PM
RE: Pine 64 benchmarks - by janjwerner - 03-08-2016, 12:07 AM
Pine 64 benchmarks - by Andrew2 - 03-08-2016, 12:34 AM
RE: Pine 64 benchmarks - by longsleep - 03-08-2016, 01:09 AM
Pine 64 benchmarks - by Andrew2 - 03-08-2016, 04:04 AM
Pine 64 benchmarks - by Andrew2 - 03-08-2016, 06:39 AM
RE: Pine 64 benchmarks - by janjwerner - 03-08-2016, 06:59 AM
Pine 64 benchmarks - by Andrew2 - 03-08-2016, 07:10 AM
RE: Pine 64 benchmarks - by janjwerner - 03-08-2016, 09:42 AM
Pine 64 benchmarks - by Andrew2 - 03-08-2016, 10:14 AM
RE: Pine 64 benchmarks - by janjwerner - 03-08-2016, 10:34 AM
Pine 64 benchmarks - by Andrew2 - 03-08-2016, 11:16 AM
RE: Pine 64 benchmarks - by longsleep - 03-08-2016, 12:31 PM
RE: Pine 64 benchmarks - by Artyom - 03-09-2016, 02:03 AM
RE: Pine 64 benchmarks - by Andrew2 - 03-09-2016, 03:53 AM
RE: Pine 64 benchmarks - by ssvb - 03-09-2016, 11:30 AM
RE: Pine 64 benchmarks - by Andrew2 - 03-09-2016, 12:12 PM
RE: Pine 64 benchmarks - by Andrew2 - 03-10-2016, 04:45 AM
RE: Pine 64 benchmarks - by Andrew2 - 03-10-2016, 10:03 AM
RE: Pine 64 benchmarks - by Andrew2 - 03-10-2016, 01:42 PM
RE: Pine 64 benchmarks - by Andrew2 - 03-11-2016, 05:03 AM
RE: Pine 64 benchmarks - by norm24 - 03-11-2016, 05:39 AM
RE: Pine 64 benchmarks - by Andrew2 - 03-11-2016, 09:59 AM
RE: Pine 64 benchmarks - by xtcrefugee - 03-11-2016, 11:35 AM
RE: Pine 64 benchmarks - by Andrew2 - 03-11-2016, 01:03 PM
RE: Pine 64 benchmarks - by tllim - 03-11-2016, 04:56 PM
RE: Pine 64 benchmarks - by Andrew2 - 03-12-2016, 01:08 PM
RE: Pine 64 benchmarks - by Andrew2 - 03-11-2016, 11:55 AM
RE: Pine 64 benchmarks - by Artyom - 03-12-2016, 03:06 AM
RE: Pine 64 benchmarks - by g_t_j - 03-15-2016, 02:28 PM
RE: Pine 64 benchmarks - by tllim - 03-15-2016, 04:19 PM
RE: Pine 64 benchmarks - by g_t_j - 03-15-2016, 04:43 PM
RE: Pine 64 benchmarks - by janjwerner - 03-15-2016, 08:41 PM
RE: Pine 64 benchmarks - by g_t_j - 03-16-2016, 06:11 AM
RE: Pine 64 benchmarks - by janjwerner - 03-15-2016, 04:46 PM
RE: Pine 64 benchmarks - by g_t_j - 03-15-2016, 05:00 PM
RE: Pine 64 benchmarks - by tllim - 03-15-2016, 07:52 PM
RE: Pine 64 benchmarks - by Andrew2 - 03-16-2016, 01:56 AM
RE: Pine 64 benchmarks - by g_t_j - 05-28-2016, 11:23 AM
RE: Pine 64 benchmarks - by tllim - 05-28-2016, 07:31 PM
RE: Pine 64 benchmarks - by g_t_j - 05-29-2016, 01:23 AM
RE: Pine 64 benchmarks - by tllim - 05-29-2016, 09:18 AM
RE: Pine 64 benchmarks - by norm24 - 03-15-2016, 11:26 PM
RE: Pine 64 benchmarks - by Andrew2 - 03-16-2016, 04:38 AM
RE: Pine 64 benchmarks - by Andrew2 - 03-16-2016, 06:04 AM
RE: Pine 64 benchmarks - by BarBrian - 03-28-2016, 11:22 PM
RE: Pine 64 benchmarks - by stealthbanana - 04-07-2016, 10:40 AM
RE: Pine 64 benchmarks - by TeaPack - 04-15-2016, 01:17 PM
RE: Pine 64 benchmarks - by tkaiser - 04-15-2016, 02:14 PM
RE: Pine 64 benchmarks - by TeaPack - 04-15-2016, 02:32 PM
RE: Pine 64 benchmarks - by tkaiser - 04-15-2016, 02:45 PM
RE: Pine 64 benchmarks - by TeaPack - 04-15-2016, 03:00 PM
  Pine A64+ mainline mipi-dsi Learnincurve 3 10,239 01-12-2021, 07:36 AM
Last Post: Learnincurve
  DietPi OS for PINE A64 MichaIng 0 12,575 12-15-2020, 06:11 AM
Last Post: MichaIng
  Fedora 32/CentOS 8 Pine A64+ Images wideawake 2 8,717 10-02-2020, 11:38 AM
Last Post: mathiraj
  LibreELEC(KODI) for Pine A64 (+) pineadmin 6 20,772 05-02-2020, 10:29 AM
Last Post: aaronmarsh632
  Lakka-nightlies for Pine A64 (and H64) roel 11 31,109 04-23-2020, 12:55 AM
Last Post: roel
  Read DHT22 on Pine A64 ayufan 3 9,903 01-19-2020, 02:51 PM
Last Post: {-DesT-}
  Centos 7 for Pine A64 Luke 2 8,864 05-28-2019, 12:18 AM
Last Post: pineadmin
  NEMS Linux for Pine A64 (+) Luke 1 8,061 05-09-2019, 05:42 PM
  Pine Board using linux stuck during boot sequence ktaragorn 4 12,576 03-30-2019, 06:48 AM
Last Post: ktaragorn
  motionEyeOS (PINE A64(+)) pineadmin 4 15,702 11-09-2018, 03:25 AM
