Pine 64 benchmarks
Benchmark comparisons like this are not useful. You need to include thermal information (eg. heat sink, fan) temperature and thermal throttling details as well including environment temperature. Also you need to make sure that you did loose any cores during one benchmark and then run the next with only 2 or even 1 core (once they are off, they are not turned on again).
This is easy to do with RPi monitor which can easily be installed on the Pine64 with the script from @tkaiser: http://kaiser-edv.de/tmp/4U4tkD/install-...for-a64.sh
Share the graphs which capture the test runs.
Also i have some scripts to monitor on the command line at https://github.com/longsleep/build-pine6...rm-scripts and to turn disabled cores back on.
This are the thermal results running my optimized BSP on the Pine64 without heat sink at 23C room temperature while the pine lies flat on the table without enclosure.
idle
# pine64_health.sh
CPU freq       : 480.00 MHz
CPU count      : 4
Governor       : interactive
Core voltage   : 1.04 V
SOC Temp       : 38 C
Cooling state  : 0
Cooling limit  : roomage:0,0,0,0,1152000,4,0,0
1 cpuburn-a8
# pine64_health.sh
CPU freq       : 1152.00 MHz
CPU count      : 4
Core voltage   : 1.30 V
SOC Temp       : 56 C
Cooling state  : 0
2 cpuburn-a8
pine64_health.sh
CPU freq       : 1104.00 MHz
CPU count      : 4
Core voltage   : 1.26 V
SOC Temp       : 74 C
Cooling state  : 1
3 cpuburn-a8
pine64_health.sh
CPU freq       : 1008.00 MHz
CPU count      : 4
Core voltage   : 1.20 V
SOC Temp       : 84 C
Cooling state  : 2
4 cpuburn-a8
# pine64_health.sh
CPU freq       : 816.00 MHz
CPU count      : 4
SOC Temp       : 91 C
Cooling state  : 3
This means, it runs stable at 816.00 MHz in cooling state 3 at around 90C with 4 cores burning with a8 optimized code. To add more load, run the cpuburn-53 code which utilized the full CPU capabilities and draws a lot more power / heat.
Also there is the undervoltage problem. If your Pine crashes/freezes it is not because of the heat - most likely you draw too much power and the USB cable / Power supply cannot provide it. Use better/shorter USB cable and another better power supply in such cases.
Cpuburn tools for arm: https://github.com/ssvb/cpuburn-arm
NOTE: Be careful with tuning the thermal details and running cpuburn - you can damage things!
Pine 64 benchmarks - by patrickhwood - 03-02-2016, 12:11 AM
RE: Pine 64 benchmarks - by nomadewolf - 03-05-2016, 02:04 PM
RE: Pine 64 benchmarks - by patrickhwood - 03-05-2016, 03:10 PM
RE: Pine 64 benchmarks - by janjwerner - 03-06-2016, 11:16 AM
RE: Pine 64 benchmarks - by tllim - 03-06-2016, 11:30 AM
RE: Pine 64 benchmarks - by patrickhwood - 03-06-2016, 11:54 AM
RE: Pine 64 benchmarks - by janjwerner - 03-06-2016, 12:05 PM
RE: Pine 64 benchmarks - by janjwerner - 03-06-2016, 01:41 PM
RE: Pine 64 benchmarks - by longsleep - 03-06-2016, 03:06 PM
RE: Pine 64 benchmarks - by janjwerner - 03-06-2016, 08:04 PM
RE: Pine 64 benchmarks - by Andrew2 - 03-07-2016, 11:30 AM
RE: Pine 64 benchmarks - by longsleep - 03-07-2016, 12:49 AM
RE: Pine 64 benchmarks - by janjwerner - 03-07-2016, 07:54 AM
RE: Pine 64 benchmarks - by longsleep - 03-07-2016, 12:43 PM
RE: Pine 64 benchmarks - by Andrew2 - 03-07-2016, 12:59 PM
RE: Pine 64 benchmarks - by janjwerner - 03-07-2016, 01:34 PM
RE: Pine 64 benchmarks - by longsleep - 03-07-2016, 01:40 PM
RE: Pine 64 benchmarks - by Andrew2 - 03-07-2016, 02:03 PM
RE: Pine 64 benchmarks - by janjwerner - 03-08-2016, 12:07 AM
Pine 64 benchmarks - by Andrew2 - 03-08-2016, 12:34 AM
RE: Pine 64 benchmarks - by longsleep - 03-08-2016, 01:09 AM
Pine 64 benchmarks - by Andrew2 - 03-08-2016, 04:04 AM
Pine 64 benchmarks - by Andrew2 - 03-08-2016, 06:39 AM
RE: Pine 64 benchmarks - by janjwerner - 03-08-2016, 06:59 AM
Pine 64 benchmarks - by Andrew2 - 03-08-2016, 07:10 AM
RE: Pine 64 benchmarks - by janjwerner - 03-08-2016, 09:42 AM
Pine 64 benchmarks - by Andrew2 - 03-08-2016, 10:14 AM
RE: Pine 64 benchmarks - by janjwerner - 03-08-2016, 10:34 AM
Pine 64 benchmarks - by Andrew2 - 03-08-2016, 11:16 AM
RE: Pine 64 benchmarks - by longsleep - 03-08-2016, 12:31 PM
RE: Pine 64 benchmarks - by Artyom - 03-09-2016, 02:03 AM
RE: Pine 64 benchmarks - by Andrew2 - 03-09-2016, 03:53 AM
RE: Pine 64 benchmarks - by ssvb - 03-09-2016, 11:30 AM
RE: Pine 64 benchmarks - by Andrew2 - 03-09-2016, 12:12 PM
RE: Pine 64 benchmarks - by Andrew2 - 03-10-2016, 04:45 AM
RE: Pine 64 benchmarks - by Andrew2 - 03-10-2016, 10:03 AM
RE: Pine 64 benchmarks - by Andrew2 - 03-10-2016, 01:42 PM
RE: Pine 64 benchmarks - by Andrew2 - 03-11-2016, 05:03 AM
RE: Pine 64 benchmarks - by norm24 - 03-11-2016, 05:39 AM
RE: Pine 64 benchmarks - by Andrew2 - 03-11-2016, 09:59 AM
RE: Pine 64 benchmarks - by xtcrefugee - 03-11-2016, 11:35 AM
RE: Pine 64 benchmarks - by Andrew2 - 03-11-2016, 01:03 PM
RE: Pine 64 benchmarks - by tllim - 03-11-2016, 04:56 PM
RE: Pine 64 benchmarks - by Andrew2 - 03-12-2016, 01:08 PM
RE: Pine 64 benchmarks - by Andrew2 - 03-11-2016, 11:55 AM
RE: Pine 64 benchmarks - by Artyom - 03-12-2016, 03:06 AM
RE: Pine 64 benchmarks - by g_t_j - 03-15-2016, 02:28 PM
RE: Pine 64 benchmarks - by tllim - 03-15-2016, 04:19 PM
RE: Pine 64 benchmarks - by g_t_j - 03-15-2016, 04:43 PM
RE: Pine 64 benchmarks - by janjwerner - 03-15-2016, 08:41 PM
RE: Pine 64 benchmarks - by g_t_j - 03-16-2016, 06:11 AM
RE: Pine 64 benchmarks - by janjwerner - 03-15-2016, 04:46 PM
RE: Pine 64 benchmarks - by g_t_j - 03-15-2016, 05:00 PM
RE: Pine 64 benchmarks - by tllim - 03-15-2016, 07:52 PM
RE: Pine 64 benchmarks - by Andrew2 - 03-16-2016, 01:56 AM
RE: Pine 64 benchmarks - by g_t_j - 05-28-2016, 11:23 AM
RE: Pine 64 benchmarks - by tllim - 05-28-2016, 07:31 PM
RE: Pine 64 benchmarks - by g_t_j - 05-29-2016, 01:23 AM
RE: Pine 64 benchmarks - by tllim - 05-29-2016, 09:18 AM
RE: Pine 64 benchmarks - by norm24 - 03-15-2016, 11:26 PM
RE: Pine 64 benchmarks - by Andrew2 - 03-16-2016, 04:38 AM
RE: Pine 64 benchmarks - by Andrew2 - 03-16-2016, 06:04 AM
RE: Pine 64 benchmarks - by BarBrian - 03-28-2016, 11:22 PM
RE: Pine 64 benchmarks - by stealthbanana - 04-07-2016, 10:40 AM
RE: Pine 64 benchmarks - by TeaPack - 04-15-2016, 01:17 PM
RE: Pine 64 benchmarks - by tkaiser - 04-15-2016, 02:14 PM
RE: Pine 64 benchmarks - by TeaPack - 04-15-2016, 02:32 PM
RE: Pine 64 benchmarks - by tkaiser - 04-15-2016, 02:45 PM
RE: Pine 64 benchmarks - by TeaPack - 04-15-2016, 03:00 PM
  Pine A64+ mainline mipi-dsi Learnincurve 3 10,147 01-12-2021, 07:36 AM
Last Post: Learnincurve
  DietPi OS for PINE A64 MichaIng 0 12,498 12-15-2020, 06:11 AM
Last Post: MichaIng
  Fedora 32/CentOS 8 Pine A64+ Images wideawake 2 8,649 10-02-2020, 11:38 AM
Last Post: mathiraj
  LibreELEC(KODI) for Pine A64 (+) pineadmin 6 20,626 05-02-2020, 10:29 AM
Last Post: aaronmarsh632
  Lakka-nightlies for Pine A64 (and H64) roel 11 30,874 04-23-2020, 12:55 AM
Last Post: roel
  Read DHT22 on Pine A64 ayufan 3 9,848 01-19-2020, 02:51 PM
Last Post: {-DesT-}
  Centos 7 for Pine A64 Luke 2 8,812 05-28-2019, 12:18 AM
Last Post: pineadmin
  NEMS Linux for Pine A64 (+) Luke 1 8,008 05-09-2019, 05:42 PM
  Pine Board using linux stuck during boot sequence ktaragorn 4 12,517 03-30-2019, 06:48 AM
Last Post: ktaragorn
  motionEyeOS (PINE A64(+)) pineadmin 4 15,634 11-09-2018, 03:25 AM
