Low power headless operation?
[quote pid='2919' dateline='1456868988']
Actually, the eMMC module can be build on the Wifi/BT connector thru SDIO 3.0 bus which is also SD bus that suitable for eMMC. We are currently explore into this path which server application don't use Wifi/BT module. Noted that there is only 4bit bus and the access speed is slower. On idle mode, the Pine A64 board goes below 0.5 watt. My guess single core headless operation runs about 2 watts.
[/quote]
So I want  to make sure that I read this correctly.  In its deepest sleep state it can consume as low as 0.5 once but if I am running a process it consumes 2.0 Watts but that is only on one core. How much does it consume with all four cores? Just curious.
I just wanted to make sure you didn't make a typo.
Also, good to hear about the idea of a POT or TOP (or whatever) eMMC. Some of the value is removed by it being slower than microsd rather than faster but it definitely serves the purpose I described!
(03-01-2016, 04:10 PM)rubenk Wrote: [quote pid='2919' dateline='1456868988']
[/quote]
Oh. Looked like about 5v at 2amps? 10 watts. Wow
Low power headless operation? - by rubenk - 03-01-2016, 01:57 PM
RE: Low power headless operation? - by tllim - 03-01-2016, 03:49 PM
RE: Low power headless operation? - by rubenk - 03-01-2016, 04:10 PM
RE: Low power headless operation? - by tllim - 03-01-2016, 10:30 PM
RE: Low power headless operation? - by tllim - 03-02-2016, 05:31 PM
RE: Low power headless operation? - by ktc - 03-18-2016, 04:38 AM
RE: Low power headless operation? - by mbt28 - 11-16-2016, 11:07 AM
RE: Low power headless operation? - by swinging - 01-05-2017, 12:37 AM
  Z-Wave - Full and Low Power Inclusion mode B34N 1 4,281 03-26-2017, 06:03 PM
Last Post: B34N
  Power Supply for Pine a64 (2GB) Pip19083 1 4,498 01-22-2017, 01:32 PM
Last Post: Luke
  Power switch circuit drewh 43 63,934 09-19-2016, 09:17 AM
Last Post: tampadave
  Power Off / Reset Buttons - DietPi casmiguefl 4 8,355 08-12-2016, 05:28 PM
Last Post: casmiguefl
  power Circuit polo 28 41,381 07-01-2016, 07:06 PM
Last Post: pfeerick
  Power over Ethernet (PoE) WLR 1 5,851 02-10-2016, 07:14 PM
  USB HDD Power eender 5 9,542 02-06-2016, 09:30 PM
Last Post: blktiger
