Analog Amplifier for Pine64
I would probably program a fixed volume on the amplifier and regulate the rest from the audio codec side so you have normal software controls, but it also depends on the output/input drive levels of your amplifier circuit. As for four channel audio, do you need 4 different channels in your car? Usually it's only two with left front/back and right front/back so you just buffer the output from the Pine and feed that to two inputs? As for the control signals, that's up to how you want to use your amp and has basically nothing to do with the Pine... I would route them to some GPIO and set sane default logic levels... Maybe also add isolation for the audio path / power supply to avoid ground loops... Since you control some things via I2C you probably need to develop a 'fake' soundcard driver so you have a mixer device to control things....
Analog Amplifier for Pine64 - by mbt28 - 02-08-2017, 08:53 AM
RE: Analog Amplifier for Pine64 - by xalius - 02-08-2017, 09:12 AM
RE: Analog Amplifier for Pine64 - by mbt28 - 02-09-2017, 08:46 AM
  Pine64 and Nexdoc mcf 11 26,523 12-05-2017, 03:10 AM
Last Post: Pander
  Mounting RPI3 "hats" on Pine64 gczuczy 5 14,618 07-30-2017, 10:29 AM
Last Post: KnReLe
  ZJ080NA-08A and pine64 mbt28 4 9,990 10-10-2016, 05:12 AM
Last Post: mbt28
  Euler bus/Pi2 bus on Pine64 xxvolwarexx 1 7,312 10-05-2016, 06:35 PM
Last Post: pfeerick
  Adafruit 16x2 LCD doesn't turn on with Pine64 mypineme 13 24,220 08-27-2016, 02:41 AM
Last Post: mypineme
Exclamation Pine64+ not starting (never) Alex89cgn 1 4,848 08-15-2016, 12:05 PM
Last Post: MarkHaysHarris777
  Pine64 Eagle LBR openhardwarecoza 3 8,097 08-01-2016, 11:05 AM
Last Post: xalius
