Better WiFi/BT module?
#20
(02-07-2017, 01:20 PM)fonix232 Wrote: Would it be possible for a 3rd party to create a better module?
I believe with the SDIO interface, it should be possible to implement a Broadcom BCM4356 (which supports SDIO v3.0 for WiFi and GPIO for BT4.0), and achieve WiFi speeds up to 867Mbps (not to mention this chip has a built-in FM receiver, which could also be used).
Also I understand that this would raise prices for such a wireless module, but for many, it would be a better choice (especially as there's no PCIe or USB3.0 port onboard). I just feel like 150Mbps is quite limited for such a versatile device.
On my pinebook, i update the kernel with recent Debian bullseye
Linux pinebook-290 5.10.0-5-arm64 #1 SMP Debian 5.10.24-1 (2021-03-19) aarch64 GNU/Linux
and also with recent Debian firmware-realtek package...
ansible@pinebook-290:~$ dpkg -l |grep firmware
ii  alsa-firmware-loaders                1.1.7-1                            arm64        ALSA software loaders for specific hardware
ii  firmware-linux-free                  3.4                                all          Binary firmware for various drivers in the Linux kernel
ii  firmware-realtek                      20210208-4                          all          Binary firmware for Realtek wired/wifi/BT adapters
After inserted r8723bs kernel module, i have in console ....
[  150.053978] r8723bs: module is from the staging directory, the quality is unknown, you have been warned.
[  150.082005] RTL8723BS: module init start
[  150.085973] RTL8723BS: rtl8723bs v4.3.5.5_12290.20140916_BTCOEX20140507-4E40
[  150.093045] RTL8723BS: rtl8723bs BT-Coex version = BTCOEX20140507-4E40
[  150.103510] RTL8723BS: module init ret =0
[  150.104008] systemd-udevd[357]: rtl8723bs: Device (SEQNUM=2815, ACTION=add) is queued
[  150.107685] systemd-udevd[357]: Validate module index
[  150.107770] systemd-udevd[357]: Check if link configuration needs reloading.
[  150.112206] systemd-udevd[357]: Successfully forked off 'n/a' as PID 4072.
[  150.112481] systemd-udevd[357]: rtl8723bs: Worker [4072] is forked for processing SEQNUM=2815.
[  150.113173] systemd-udevd[357]: r8723bs: Device (SEQNUM=2816, ACTION=add) is queued
[  150.113523] systemd-udevd[4072]: rtl8723bs: Processing device (SEQNUM=2815, ACTION=add)
[  150.114573] systemd-udevd[357]: Successfully forked off 'n/a' as PID 4073.
[  150.114927] systemd-udevd[357]: r8723bs: Worker [4073] is forked for processing SEQNUM=2816.
[  150.116757] systemd-udevd[4073]: r8723bs: Processing device (SEQNUM=2816, ACTION=add)
and no network device is created, so that no WLAN interface  (!)
Any idea ?
Thanks in advance
Better WiFi/BT module? - by fonix232 - 02-07-2017, 01:20 PM
RE: Better WiFi/BT module? - by mbt28 - 02-08-2017, 05:31 AM
RE: Better WiFi/BT module? - by fonix232 - 02-08-2017, 07:03 AM
RE: Better WiFi/BT module? - by dkryder - 02-08-2017, 10:09 AM
RE: Better WiFi/BT module? - by DonFL - 02-08-2017, 11:25 AM
RE: Better WiFi/BT module? - by pfeerick - 02-08-2017, 09:28 PM
RE: Better WiFi/BT module? - by fonix232 - 02-09-2017, 06:05 AM
RE: Better WiFi/BT module? - by dkryder - 02-08-2017, 03:11 PM
RE: Better WiFi/BT module? - by DonFL - 02-08-2017, 04:53 PM
RE: Better WiFi/BT module? - by DonFL - 02-09-2017, 06:45 AM
RE: Better WiFi/BT module? - by mbt28 - 02-09-2017, 06:49 AM
RE: Better WiFi/BT module? - by xalius - 02-09-2017, 06:57 AM
RE: Better WiFi/BT module? - by mbt28 - 02-09-2017, 07:49 AM
RE: Better WiFi/BT module? - by xalius - 02-09-2017, 08:29 AM
RE: Better WiFi/BT module? - by fonix232 - 02-09-2017, 11:35 AM
RE: Better WiFi/BT module? - by tllim - 02-12-2017, 10:43 PM
RE: Better WiFi/BT module? - by fonix232 - 02-13-2017, 03:52 AM
RE: Better WiFi/BT module? - by xalius - 02-13-2017, 04:38 AM
RE: Better WiFi/BT module? - by mikeb - 01-19-2020, 03:24 AM
RE: Better WiFi/BT module? - by Jean-Marc LACROIX - 03-27-2021, 12:21 PM
RE: Better WiFi/BT module? - by Jean-Marc LACROIX - 08-11-2021, 09:27 AM
  [split] Better WiFi/BT module? moriel5 3 4,994 05-18-2022, 01:55 PM
Last Post: moriel5
  WIFI/BT Power Supply / VBAT-EXT xalius 3 4,690 08-12-2021, 06:41 AM
Last Post: Luke490
  Wifi / Bluetooth Board Update S265 2 4,137 07-30-2020, 04:53 PM
Last Post: S265
  Create a WiFi hotspot on Debian 8 JulianM 6 27,016 03-10-2019, 01:02 AM
Last Post: waqasnasir
  Schematics of Wifi/BT module gamelaster 7 9,655 09-11-2018, 02:02 PM
Last Post: gamelaster
  Wireless Module Driver Source code mido2018 0 2,018 08-08-2018, 04:26 PM
Last Post: mido2018
  Installing another WiFi module on one of the buses mido2018 1 3,545 07-22-2018, 07:15 AM
  Unable to activate wifi on Linux smouton 10 15,787 02-21-2018, 09:56 PM
Last Post: dkebler
  Pine64 doesn't recognize Wifi/BT Module clobeca 3 6,020 07-13-2017, 08:58 PM
Last Post: MarkHaysHarris777
Sad wifi direct bj_jung 2 5,361 12-29-2016, 10:26 AM
Last Post: happytuna
