Better WiFi/BT module?
You have to keep in mind that SDIO is not PCIe or USB3.0 :-)
Does anyone know what the maximum bus speed for SDIO3.0 is on the A64?
http://files.pine64.org/doc/datasheet/pi...t_V1.1.pdf page 41
If I read this correct, the SDC1 controller supports either
DS,HS,SDR12,SDR25,SDR50,SDR104
DDR50
SDR104 has a bus clock of 150Mhz, whichs means that at 4 bit you would get theoretically 600Mbit/s raw bit rate minus the frame/protocol overhead,
so in practice probably quite a bit less?
Tyical SDIO3.0 Wifi modules have around 433Mbit https://boundarydevices.com/product/bd_sdmac_wifi/
You also need 1.8V signaling for the SDR104 mode... which is maybe possible because Port G seems to be connected to it's own DLDO/ELDO
http://files.pine64.org/doc/Pine%20A64%2...elease.pdf
http://files.pine64.org/doc/datasheet/pi...t_V1.0.pdf
ELDO1 is adjustable from 0.7-1.9V (Imax 400mA)
DLDO4 is adjustable from 0.7-3.3V (Imax 500mA)
Faster modules might still give a little bit more headroom for link degradation...
Better WiFi/BT module? - by fonix232 - 02-07-2017, 01:20 PM
RE: Better WiFi/BT module? - by mbt28 - 02-08-2017, 05:31 AM
RE: Better WiFi/BT module? - by fonix232 - 02-08-2017, 07:03 AM
RE: Better WiFi/BT module? - by dkryder - 02-08-2017, 10:09 AM
RE: Better WiFi/BT module? - by DonFL - 02-08-2017, 11:25 AM
RE: Better WiFi/BT module? - by pfeerick - 02-08-2017, 09:28 PM
RE: Better WiFi/BT module? - by fonix232 - 02-09-2017, 06:05 AM
RE: Better WiFi/BT module? - by dkryder - 02-08-2017, 03:11 PM
RE: Better WiFi/BT module? - by DonFL - 02-08-2017, 04:53 PM
RE: Better WiFi/BT module? - by DonFL - 02-09-2017, 06:45 AM
RE: Better WiFi/BT module? - by mbt28 - 02-09-2017, 06:49 AM
RE: Better WiFi/BT module? - by xalius - 02-09-2017, 06:57 AM
RE: Better WiFi/BT module? - by mbt28 - 02-09-2017, 07:49 AM
RE: Better WiFi/BT module? - by xalius - 02-09-2017, 08:29 AM
RE: Better WiFi/BT module? - by fonix232 - 02-09-2017, 11:35 AM
RE: Better WiFi/BT module? - by tllim - 02-12-2017, 10:43 PM
RE: Better WiFi/BT module? - by fonix232 - 02-13-2017, 03:52 AM
RE: Better WiFi/BT module? - by xalius - 02-13-2017, 04:38 AM
RE: Better WiFi/BT module? - by mikeb - 01-19-2020, 03:24 AM
RE: Better WiFi/BT module? - by Jean-Marc LACROIX - 03-27-2021, 12:21 PM
RE: Better WiFi/BT module? - by Jean-Marc LACROIX - 08-11-2021, 09:27 AM
  [split] Better WiFi/BT module? moriel5 3 4,957 05-18-2022, 01:55 PM
Last Post: moriel5
  WIFI/BT Power Supply / VBAT-EXT xalius 3 4,667 08-12-2021, 06:41 AM
Last Post: Luke490
  Wifi / Bluetooth Board Update S265 2 4,118 07-30-2020, 04:53 PM
Last Post: S265
  Create a WiFi hotspot on Debian 8 JulianM 6 26,964 03-10-2019, 01:02 AM
Last Post: waqasnasir
  Schematics of Wifi/BT module gamelaster 7 9,614 09-11-2018, 02:02 PM
Last Post: gamelaster
  Wireless Module Driver Source code mido2018 0 2,014 08-08-2018, 04:26 PM
Last Post: mido2018
  Installing another WiFi module on one of the buses mido2018 1 3,520 07-22-2018, 07:15 AM
  Unable to activate wifi on Linux smouton 10 15,717 02-21-2018, 09:56 PM
Last Post: dkebler
  Pine64 doesn't recognize Wifi/BT Module clobeca 3 6,003 07-13-2017, 08:58 PM
Last Post: MarkHaysHarris777
Sad wifi direct bj_jung 2 5,335 12-29-2016, 10:26 AM
Last Post: happytuna
