Updating Ubuntu 16.04
(01-31-2017, 08:06 AM)MarkHaysHarris777 Wrote:
(01-31-2017, 07:34 AM)SteveBlack Wrote: <snip>
However, I did a check for updates and there are some.
But Ubuntu tells me there isn't enough space on /boot to do the updates.
I've checked the structure of the MicroSD and there is a small unallocated space at the beginning, /boot, which is about 52MB followed by / which takes up the rest of the 32GB space.
Is there a reason why the updates are trying to install to /boot rather than /?
I am fairly certain that you are misinterpretting something .
... reboot your pine board and open a terminal.  Next ;  sudo -i
cd
apt update
apt upgrade
... see if that works.
Its not going to try to put the updates on /boot...
Many thanks for this advice. It worked perfectly.
I was trying to update from the Mate System/Administration/Software Updater menu option, which listed a number of updates. When I clicked 'Install' I got the dialog in the attachment to this post.
I then used 'apt update' and 'apt upgrade' as you advised and all of the updates were installed. I then rebooted and used the System/Administration/Software Updater menu option again and Ubuntu reports that the system is up to date.
I'm happy that the update is done, but as you can see from my attached screenshot, there is an issue about space on /boot.
I'll use the terminal to update in future, but I thought it useful to post the screenshot.
Updating Ubuntu 16.04 - by SteveBlack - 01-31-2017, 07:34 AM
RE: Updating Ubuntu 16.04 - by MarkHaysHarris777 - 01-31-2017, 08:06 AM
RE: Updating Ubuntu 16.04 - by ta2025 - 05-05-2017, 01:33 PM
RE: Updating Ubuntu 16.04 - by SteveBlack - 01-31-2017, 03:18 PM
RE: Updating Ubuntu 16.04 - by pfeerick - 02-01-2017, 01:04 AM
RE: Updating Ubuntu 16.04 - by martinayotte - 02-01-2017, 10:26 AM
RE: Updating Ubuntu 16.04 - by kenneth558 - 03-10-2017, 01:38 PM
RE: Updating Ubuntu 16.04 - by SteveBlack - 02-03-2017, 03:26 PM
RE: Updating Ubuntu 16.04 - by martinayotte - 03-11-2017, 09:02 AM
RE: Updating Ubuntu 16.04 - by kenneth558 - 03-11-2017, 11:53 AM
  Ubuntu server 20.04 request phi0x 2 5,388 12-30-2020, 08:02 PM
Last Post: phi0x
  SPI on ubuntu IlyaM 4 9,254 07-16-2018, 03:00 AM
Last Post: kingflab
  Ubuntu password not working joemassimino 4 8,683 05-18-2018, 03:33 PM
Last Post: Luke
  After flashing Ubuntu- how to get graphical desktop Partymack711 6 11,001 02-01-2018, 09:45 AM
Last Post: Partymack711
  (ARCHIVED) Ubuntu Xenial Image (BSP Kernel) longsleep 337 643,120 01-31-2018, 11:58 AM
Last Post: Luke
  PPTP doesnt work with ubuntu escovedo 2 8,793 08-23-2017, 09:28 AM
Last Post: gilbertotcc
Question HELP Ubuntu Mate password recovery procedure Captain Anni Hilator 5 10,090 08-03-2017, 03:52 PM
Last Post: Luke
  Ubuntu boot very slow with wifi driver remainder 9 20,866 08-03-2017, 07:23 AM
Last Post: victorssantos
  Recovering root access in Ubuntu Scientomancer 3 5,947 07-28-2017, 02:53 PM
Last Post: Scientomancer
  Pine64 2Gb Ubuntu Mono not updating and stuck petec 0 2,912 07-08-2017, 09:34 AM
Last Post: petec
