power supply
#21
Power consumption is hard to predict. It's hardly depend on your application and if you attach external devices. e.g. USB devices.
I have found a compact 5V 4A PSU at Aliexpress for less than 5$ (including shipment)
I will not recommend to use the micro USB connector for permanent power connection. It should be possible to connect power to the EULA pin connector as well and then use a wire dimension suitable to the power load. (But be careful, use the correct pins and respect the polarity, else can the board be damaged)
power supply - by Phlebas - 02-17-2016, 05:18 AM
RE: power supply - by Ghost - 02-17-2016, 05:29 AM
RE: power supply - by Phlebas - 02-17-2016, 05:38 AM
RE: power supply - by MichaelMeissner - 02-17-2016, 07:03 AM
RE: power supply - by Ghost - 02-17-2016, 07:05 AM
RE: power supply - by Phlebas - 02-17-2016, 08:49 AM
RE: power supply - by tllim - 02-17-2016, 09:49 PM
RE: power supply - by By-Jokese - 02-21-2016, 06:15 AM
RE: power supply - by tllim - 02-21-2016, 09:13 PM
RE: USB 5V 2A Or 5V 2.1A power supply with microusb cable can run PINE64? - by gbjensen - 03-16-2016, 03:48 AM
  New RockPro64 Power Up Problem enorbet2 7 4,981 10-28-2023, 12:08 PM
Last Post: dkebler
  Pinecil power Erincka 0 1,855 03-21-2021, 11:52 AM
Last Post: Erincka
  Session fails to fully start after unexpected power off during initial upgrade Avron 0 1,926 03-18-2021, 11:52 AM
Last Post: Avron
  Power button sdziuba 1 2,409 03-14-2021, 09:05 AM
Last Post: xalius
  PBP won't power. Charge light solid orange/red but turns off. cmicallef 15 12,321 03-12-2021, 07:08 PM
Last Post: cmicallef
  howto power hdd via usb3 on rockpro64 hanscees 2 5,075 06-17-2020, 02:00 AM
Last Post: hanscees
  User Screen Black After Changing Power Settings 0b51Gekko 2 4,744 07-03-2019, 07:53 AM
Last Post: 0b51Gekko
  5.25 V _ ... 2A Power USB Adapter Guest2000 4 7,071 02-12-2017, 09:34 PM
  Power Switch for Pine64 512MB Board MonarchOfLight 0 2,536 10-24-2016, 04:33 PM
Last Post: MonarchOfLight
  Power Ribbon for LCD Display Plot 3 6,094 10-23-2016, 12:16 PM
Last Post: dkryder
