Current known limitations of Pine64
Well there are the various things that pine64 does not have that might be useful in a future version, but a lot of these might bump the chip into a higher price bracket:
  • Sata port(s)
  • USB-3 instead of USB-2 (but backwards compatible with USB-2)
  • More memory
  • 2.1mm power connection
  • Faster/newer processor
  • Onboard flash memory that you can install an OS to in addition to micro-SD card and/or 2nd flash drive
  • Having on board temp, motion sensor
  • Having on board GPS
  • Having a better camera as an add-on
However, with the current board:
  • Update the wiki connector page (http://wiki.pine64.org/images/d/da/Pine64_Connector.JPG) to specify the exact plug used (i.e. enough detail that you could order the part from digikey), specifying that the 2x17 and 2x20 pinouts are 0.1", the microphone is 3.5mm stereo with microphone (and pinout for the 3.5mm), power switch, IR sensor, etc.;
  • Provide pinout documents for the camera/lcd/touch panel connectors;
  • What pins (if any) are 5v tolerant;
  • How to access all of the pins/buses on the pi-2/euler/wifi breakout areas in both Android and Linux OSes;
  • What is needed to adjust the RTC for different temps;
  • Specify exactly what type of lithium battery can be connected to the pine64;
  • Provide wattage (power draw) for the pine64 under different scenarios (low power mode, with ethernet enabled, with wifi/bluetooth attached, with LCD attached, with both LCD and camera attached, etc.), and give how long the pine64 will run with the 8000mAh battery.
Current known limitations of Pine64 - by SkimMilk - 02-15-2016, 11:30 PM
RE: Current known limitations of Pine64 - by MichaelMeissner - 02-16-2016, 07:23 AM
Question External storage problem for pine64 Dani6102 4 1,754 08-22-2023, 08:36 AM
Last Post: gulshan212
  Pine64 as wireless audio device S265 3 3,307 04-07-2022, 10:39 PM
Last Post: S265
  Pine64(+) and manjaro dsychan 0 1,165 04-05-2022, 11:32 PM
Last Post: dsychan
Thumbs Down Pine64 was a Useless Project pushpendrak 18 28,893 11-21-2020, 10:17 PM
  Pine64 LCD rstcologne 0 3,139 09-22-2020, 12:43 PM
Last Post: rstcologne
  Pine64+ power button PaddyChan 0 2,788 09-14-2020, 09:55 AM
Last Post: PaddyChan
  Pine64 OS dpcons 2 4,977 03-02-2020, 04:32 PM
Last Post: dpcons
  Jailhouse supports Pine64+ vj-kumar 0 2,848 02-17-2020, 11:39 PM
Last Post: vj-kumar
  PINE64 board not powering up loki21century 2 5,615 11-25-2019, 12:19 PM
Last Post: Partymack711
  Pine64 not powering up. skylab 5 7,289 05-03-2019, 02:48 PM
Last Post: Mendota
