debian i2c-dev
Big Grin
(12-16-2016, 08:09 AM)pine.adam Wrote:
(12-16-2016, 08:06 AM)KnReLe Wrote: Hardware-wise you seem to be OK. The problem is with high-level software (the python library that talks to the /dev/i2c-1 device).
You might want to check out the RPi.GPIO-PineA64 library that was linked to by martinayotte on this thread;
http://forum.pine64.org/showthread.php?tid=2935
I haven't done that much with this myself, but the idea is to provide a similar utility library for the PineA64 as is seen on Raspberry Pi machines.
Will do - I was just in the process of digging through the ADS1x15 python code to try to understand it a little better.
Thanks!
-Adam
Was messing with the pine today and realized I didn't need the ADS1115. Used my arduino uno instead.
Successfully measuring 0-5v through the analog input and python code watching the the arduino output connected through the usb/serial.
Even better, writing to a .csv file
had a 3.3v through a 10k ohm potentiometer watching the outputs change.
Had to leave some work for Monday - add 1min delay in voltage print loop, add date/time stamp, and write to a new line in the .csv instead of overwriting first line in every instance.
should be pretty simple.
Happy to be doing this on the pine.
Thanks!
debian i2c-dev - by pine.adam - 12-15-2016, 09:32 AM
RE: debian i2c-dev - by KnReLe - 12-16-2016, 02:49 AM
RE: debian i2c-dev - by KnReLe - 12-16-2016, 05:19 AM
RE: debian i2c-dev - by pine.adam - 12-16-2016, 07:31 AM
RE: debian i2c-dev - by KnReLe - 12-16-2016, 08:06 AM
RE: debian i2c-dev - by pine.adam - 12-16-2016, 08:09 AM
RE: debian i2c-dev - by pine.adam - 12-16-2016, 04:21 PM
  Debian installer on Pine A64+ but no hdmi mrwick 1 4,930 07-28-2020, 01:49 PM
Last Post: kuleszdl
  Debian Pine64 h264/5 Video under vlc ozcy 6 12,879 04-15-2020, 05:27 AM
Last Post: dmitrymyadzelets
  OMV/debian/systemd: how to start the network kittyland 0 2,974 12-10-2019, 05:29 PM
Last Post: kittyland
  Debian 10 (Buster) in deep freeze - includes support for Pine64+ amp 5 10,193 07-22-2019, 09:29 PM
Last Post: amp
  Pine64 Debian Stretch/mainline [4.14.7] CallMeFoxie 50 122,044 07-22-2019, 09:24 PM
Last Post: amp
  Installing Debian with the Debian Installer (Buster RC1) amp 1 4,798 06-28-2019, 12:35 PM
Last Post: Kaarme42
  Script to build pure Debian images for Pine64+ amp 1 4,232 05-01-2019, 09:09 PM
  Debian (Stretch) for Pine64-LTS wgray 2 6,331 04-04-2019, 09:54 PM
Last Post: wgray
  Is there just one fuctioning Debian Desktop image? KNERD 7 13,191 03-29-2019, 02:00 AM
Last Post: desai_amogh
  (ARCHIVED) Debian Jessie Images (3.10.102 BSP Kernel) New Release lenny.raposo-pine64.pro 259 465,362 05-21-2018, 06:30 AM
Last Post: Luke
