Kernel for A64 git
#91
(05-07-2016, 06:48 AM)Terra854 Wrote:
(05-07-2016, 05:45 AM)longsleep Wrote: You still have to worry as Kernel 3.10 is officially end of life since Dec 2015. It still gets the occasional update but its still a very old Kernel tree.
The EOL is actually on October 2017 (longterm maintainence release)
Oh someone took over the 3.10 line recently. Thanks for the hint - i missed that. So its indeed Oct, 2017 now. So then still do not feel safe because of what tkaiser said.
(05-07-2016, 06:48 AM)Terra854 Wrote: By the way, the upgrade script fails to detect the latest version (3.10.101). It shows that the kernel that I have (3.10.65) is at it's latest version.
I do not see how this could be the case. You know that its not really checking what you run? It is just comparing etags with what it stored before in /var/lib/misc/pine64_update_kernel.status - so remove that file to force it download and apply again.
(05-07-2016, 06:37 AM)tkaiser Wrote:
(05-07-2016, 06:28 AM)longsleep Wrote: I wanted to check if i could do 720p in U-Boot and show a boot logo and then switch to 1080p with the tool later.
Agreed. This is even better. Resolution switching works fine here but only until X is started. Afterwards it gets messy. So adjusting resolution in uEnv.txt should be the preferred method and people shouldn't be aware that sunxi-disp-tool even exists Smile
Yes - If X runs, the framebuffer cannot be released and recreated or something. So X needs to stop, then change resolution, start X and everything is good. Also wrote it in the README at https://github.com/longsleep/sunxi-disp-...E.md#usage to be sure i can point and say see here - i said so Smile
Kernel for A64 git - by longsleep - 02-14-2016, 03:00 AM
RE: Kernel for A64 git - by drag00n - 02-14-2016, 04:12 AM
RE: Kernel for A64 git - by longsleep - 02-14-2016, 04:28 AM
RE: Kernel for A64 git - by drag00n - 02-14-2016, 04:31 AM
RE: Kernel for A64 git - by umiddelb - 02-15-2016, 07:25 AM
RE: Kernel for A64 git - by longsleep - 02-15-2016, 11:05 AM
RE: Kernel for A64 git - by umiddelb - 02-15-2016, 12:11 PM
RE: Kernel for A64 git - by longsleep - 02-15-2016, 12:35 PM
RE: Kernel for A64 git - by longsleep - 02-21-2016, 06:47 AM
RE: Kernel for A64 git - by longsleep - 02-22-2016, 03:09 PM
RE: Kernel for A64 git - by longsleep - 02-23-2016, 02:53 PM
RE: Kernel for A64 git - by tllim - 02-23-2016, 04:28 PM
RE: Kernel for A64 git - by patrickhwood - 02-23-2016, 10:13 PM
RE: Kernel for A64 git - by longsleep - 02-24-2016, 12:36 AM
RE: Kernel for A64 git - by tllim - 02-24-2016, 06:54 PM
RE: Kernel for A64 git - by longsleep - 02-25-2016, 01:16 AM
RE: Kernel for A64 git - by umiddelb - 02-25-2016, 05:04 AM
RE: Kernel for A64 git - by patrickhwood - 02-25-2016, 10:01 AM
RE: Kernel for A64 git - by duanhongyi - 02-25-2016, 01:51 AM
RE: Kernel for A64 git - by longsleep - 02-25-2016, 06:15 AM
RE: Kernel for A64 git - by umiddelb - 02-26-2016, 02:46 AM
RE: Kernel for A64 git - by longsleep - 02-26-2016, 09:15 AM
RE: Kernel for A64 git - by longsleep - 02-28-2016, 03:36 AM
RE: Kernel for A64 git - by patrickhwood - 03-02-2016, 09:52 PM
RE: Kernel for A64 git - by patrickhwood - 03-04-2016, 11:45 AM
RE: Kernel for A64 git - by longsleep - 03-05-2016, 03:41 AM
RE: Kernel for A64 git - by longsleep - 03-06-2016, 10:36 AM
RE: Kernel for A64 git - by tllim - 03-06-2016, 10:47 AM
RE: Kernel for A64 git - by longsleep - 03-06-2016, 10:59 AM
RE: Kernel for A64 git - by longsleep - 03-12-2016, 03:14 AM
RE: Kernel for A64 git - by longsleep - 03-12-2016, 10:39 AM
RE: Kernel for A64 git - by sbhere - 03-13-2016, 09:34 PM
RE: Kernel for A64 git - by Terra854 - 03-17-2016, 09:14 PM
RE: Kernel for A64 git - by longsleep - 03-19-2016, 03:32 PM
RE: Kernel for A64 git - by tllim - 03-19-2016, 08:41 PM
RE: Kernel for A64 git - by duanhongyi - 03-23-2016, 06:27 AM
RE: Kernel for A64 git - by Andrew2 - 03-23-2016, 06:32 AM
RE: Kernel for A64 git - by janjwerner - 03-23-2016, 12:51 PM
RE: Kernel for A64 git - by falk.ben@gmail.com - 03-24-2016, 01:16 PM
RE: Kernel for A64 git - by janjwerner - 03-24-2016, 06:42 PM
RE: Kernel for A64 git - by keiothic - 03-30-2016, 03:00 PM
RE: Kernel for A64 git - by ak_hepcat - 03-30-2016, 06:18 PM
RE: Kernel for A64 git - by janjwerner - 03-30-2016, 07:47 PM
RE: Kernel for A64 git - by patrickhwood - 03-31-2016, 08:49 AM
RE: Kernel for A64 git - by longsleep - 03-31-2016, 10:42 AM
RE: Kernel for A64 git - by ak_hepcat - 03-31-2016, 11:58 AM
RE: Kernel for A64 git - by DaveKram - 04-01-2016, 07:21 AM
RE: Kernel for A64 git - by ak_hepcat - 04-01-2016, 09:54 AM
RE: Kernel for A64 git - by longsleep - 04-03-2016, 03:03 AM
RE: Kernel for A64 git - by mane - 04-07-2016, 03:08 AM
RE: Kernel for A64 git - by Terra854 - 04-08-2016, 09:26 AM
RE: Kernel for A64 git - by longsleep - 04-08-2016, 10:13 AM
RE: Kernel for A64 git - by Terra854 - 04-11-2016, 01:21 AM
RE: Kernel for A64 git - by longsleep - 04-11-2016, 12:01 PM
RE: Kernel for A64 git - by longsleep - 04-16-2016, 03:49 AM
RE: Kernel for A64 git - by tomekr - 04-16-2016, 07:11 AM
RE: Kernel for A64 git - by longsleep - 04-16-2016, 07:56 AM
RE: Kernel for A64 git - by rahlquist - 04-16-2016, 06:33 PM
RE: Kernel for A64 git - by Hart - 04-16-2016, 09:42 PM
RE: Kernel for A64 git - by peterz - 04-17-2016, 03:26 AM
RE: Kernel for A64 git - by peterz - 04-17-2016, 04:44 AM
RE: Kernel for A64 git - by thantik - 04-17-2016, 01:22 PM
RE: Kernel for A64 git - by Hart - 04-17-2016, 05:14 PM
RE: Kernel for A64 git - by Terra854 - 04-20-2016, 09:05 PM
RE: Kernel for A64 git - by jocover - 04-21-2016, 02:01 AM
RE: Kernel for A64 git - by Pirin - 04-23-2016, 09:28 AM
RE: Kernel for A64 git - by longsleep - 04-23-2016, 09:33 AM
RE: Kernel for A64 git - by Pirin - 04-23-2016, 09:50 AM
RE: Kernel for A64 git - by longsleep - 04-23-2016, 01:15 PM
RE: Kernel for A64 git - by ak_hepcat - 04-25-2016, 04:05 PM
RE: Kernel for A64 git - by insignia96 - 04-27-2016, 12:09 AM
RE: Kernel for A64 git - by ak_hepcat - 04-27-2016, 10:50 AM
RE: Kernel for A64 git - by longsleep - 05-02-2016, 01:55 PM
RE: Kernel for A64 git - by longsleep - 05-03-2016, 03:14 PM
RE: Kernel for A64 git - by tkaiser - 05-06-2016, 10:02 AM
RE: Kernel for A64 git - by longsleep - 05-06-2016, 10:47 AM
RE: Kernel for A64 git - by tkaiser - 05-06-2016, 11:16 AM
RE: Kernel for A64 git - by janjwerner - 05-06-2016, 11:21 AM
RE: Kernel for A64 git - by tkaiser - 05-07-2016, 01:06 AM
RE: Kernel for A64 git - by longsleep - 05-07-2016, 01:14 AM
RE: Kernel for A64 git - by longsleep - 05-07-2016, 04:24 AM
RE: Kernel for A64 git - by Terra854 - 05-07-2016, 05:40 AM
RE: Kernel for A64 git - by longsleep - 05-07-2016, 05:45 AM
RE: Kernel for A64 git - by tkaiser - 05-07-2016, 06:08 AM
RE: Kernel for A64 git - by rahlquist - 05-07-2016, 06:20 AM
RE: Kernel for A64 git - by longsleep - 05-07-2016, 06:28 AM
RE: Kernel for A64 git - by tkaiser - 05-07-2016, 06:37 AM
RE: Kernel for A64 git - by rahlquist - 05-07-2016, 06:54 AM
RE: Kernel for A64 git - by tllim - 05-07-2016, 11:15 AM
RE: Kernel for A64 git - by Terra854 - 05-07-2016, 06:48 AM
RE: Kernel for A64 git - by longsleep - 05-07-2016, 06:57 AM
RE: Kernel for A64 git - by tkaiser - 05-07-2016, 07:03 AM
RE: Kernel for A64 git - by longsleep - 05-07-2016, 07:04 AM
RE: Kernel for A64 git - by Terra854 - 05-07-2016, 08:13 AM
RE: Kernel for A64 git - by tkaiser - 05-07-2016, 09:36 AM
RE: Kernel for A64 git - by Terra854 - 05-07-2016, 10:54 AM
RE: Kernel for A64 git - by longsleep - 05-07-2016, 08:19 AM
RE: Kernel for A64 git - by longsleep - 05-07-2016, 11:26 AM
RE: Kernel for A64 git - by rhkean - 05-07-2016, 03:10 PM
RE: Kernel for A64 git - by longsleep - 05-07-2016, 03:28 PM
RE: Kernel for A64 git - by longsleep - 05-16-2016, 02:30 PM
RE: Kernel for A64 git - by ak_hepcat - 05-19-2016, 12:24 PM
RE: Kernel for A64 git - by longsleep - 05-19-2016, 12:42 PM
RE: Kernel for A64 git - by ak_hepcat - 05-19-2016, 01:25 PM
RE: Kernel for A64 git - by longsleep - 05-21-2016, 12:24 PM
RE: Kernel for A64 git - by longsleep - 05-24-2016, 03:49 PM
RE: Kernel for A64 git - by longsleep - 05-26-2016, 01:44 PM
RE: Kernel for A64 git - by ak_hepcat - 05-27-2016, 12:14 PM
RE: Kernel for A64 git - by lvcargnini - 05-27-2016, 03:43 PM
RE: Kernel for A64 git - by Terra854 - 05-27-2016, 09:30 PM
RE: Kernel for A64 git - by longsleep - 06-17-2016, 02:32 PM
RE: Kernel for A64 git - by ak_hepcat - 07-05-2016, 11:57 PM
RE: Kernel for A64 git - by longsleep - 07-16-2016, 02:47 AM
RE: Kernel for A64 git - by Luxus - 07-10-2016, 02:45 AM
RE: Kernel for A64 git - by xalius - 07-10-2016, 03:22 AM
RE: Kernel for A64 git - by longsleep - 07-16-2016, 06:25 AM
RE: Kernel for A64 git - by ak_hepcat - 07-17-2016, 10:14 AM
RE: Kernel for A64 git - by scorn4society - 07-24-2016, 12:57 AM
RE: Kernel for A64 git - by longsleep - 07-24-2016, 01:02 AM
RE: Kernel for A64 git - by xalius - 07-16-2016, 12:12 PM
RE: Kernel for A64 git - by dkulinski - 07-18-2016, 07:47 PM
RE: Kernel for A64 git - by ak_hepcat - 07-20-2016, 05:37 PM
RE: Kernel for A64 git - by modsbyus - 07-24-2016, 05:08 AM
RE: Kernel for A64 git - by longsleep - 07-24-2016, 08:04 AM
RE: Kernel for A64 git - by xalius - 07-27-2016, 11:34 AM
RE: Kernel for A64 git - by longsleep - 07-27-2016, 02:36 PM
RE: Kernel for A64 git - by Drakuwa - 08-10-2016, 10:28 AM
RE: Kernel for A64 git - by longsleep - 08-10-2016, 10:34 AM
RE: Kernel for A64 git - by Drakuwa - 08-10-2016, 10:48 AM
RE: Kernel for A64 git - by longsleep - 08-20-2016, 03:52 PM
RE: Kernel for A64 git - by RaimundEge - 08-22-2016, 04:14 PM
RE: Kernel for A64 git - by longsleep - 08-22-2016, 11:38 PM
RE: Kernel for A64 git - by nSkaarup - 08-25-2016, 08:06 AM
RE: Kernel for A64 git - by Terra854 - 09-16-2016, 07:30 AM
RE: Kernel for A64 git - by ak_hepcat - 09-17-2016, 06:04 PM
RE: Kernel for A64 git - by Terra854 - 09-18-2016, 02:00 AM
RE: Kernel for A64 git - by Detritus - 09-19-2016, 04:23 AM
RE: Kernel for A64 git - by Terra854 - 09-19-2016, 07:59 AM
RE: Kernel for A64 git - by fneves - 09-27-2016, 06:12 AM
RE: Kernel for A64 git - by v.podzimek - 10-12-2016, 09:56 AM
RE: Kernel for A64 git - by longsleep - 10-12-2016, 10:01 AM
RE: Kernel for A64 git - by v.podzimek - 10-23-2016, 08:19 AM
RE: Kernel for A64 git - by longsleep - 10-23-2016, 06:52 AM
RE: Kernel for A64 git - by MarkHaysHarris777 - 10-23-2016, 08:07 AM
RE: Kernel for A64 git - by mrv - 10-23-2016, 12:49 PM
RE: Kernel for A64 git - by longsleep - 10-29-2016, 07:09 AM
RE: Kernel for A64 git - by hahn - 10-29-2016, 07:15 AM
RE: Kernel for A64 git - by tllim - 10-31-2016, 04:20 PM
RE: Kernel for A64 git - by androsch - 11-10-2016, 04:21 AM
RE: Kernel for A64 git - by ak_hepcat - 11-17-2016, 01:15 PM
RE: Kernel for A64 git - by androsch - 11-17-2016, 02:10 PM
RE: Kernel for A64 git - by androsch - 11-18-2016, 12:52 AM
RE: Kernel for A64 git - by ak_hepcat - 11-20-2016, 08:56 PM
RE: Kernel for A64 git - by androsch - 11-21-2016, 01:07 PM
RE: Kernel for A64 git - by ak_hepcat - 12-07-2016, 05:49 PM
RE: Kernel for A64 git - by waldo - 11-01-2016, 01:29 PM
RE: Kernel for A64 git - by stepw - 11-01-2016, 09:22 PM
RE: Kernel for A64 git - by marcus - 11-02-2016, 09:31 AM
RE: Kernel for A64 git - by gkkpch - 11-06-2016, 02:09 PM
RE: Kernel for A64 git - by MarkHaysHarris777 - 11-18-2016, 01:45 AM
RE: Kernel for A64 git - by benjanyan - 12-03-2016, 05:05 AM
RE: Kernel for A64 git - by pfeerick - 12-03-2016, 06:27 PM
RE: Kernel for A64 git - by longsleep - 12-16-2016, 02:57 PM
RE: Kernel for A64 git - by tllim - 12-16-2016, 07:46 PM
RE: Kernel for A64 git - by androsch - 12-17-2016, 01:42 AM
RE: Kernel for A64 git - by HenryD - 12-21-2016, 12:24 PM
RE: Kernel for A64 git - by longsleep - 12-21-2016, 12:34 PM
RE: Kernel for A64 git - by default - 01-06-2017, 05:44 PM
RE: Kernel for A64 git - by mbt28 - 01-23-2017, 02:20 PM
RE: Kernel for A64 git - by mont3z - 01-26-2017, 03:47 PM
RE: Kernel for A64 git - by mbt28 - 01-27-2017, 02:33 AM
RE: Kernel for A64 git - by longsleep - 03-11-2017, 12:19 PM
RE: Kernel for A64 git - by hahn - 03-12-2017, 02:43 AM
RE: Kernel for A64 git - by chadbhowell - 03-11-2017, 08:16 PM
RE: Kernel for A64 git - by Charles - 09-05-2017, 04:57 AM
RE: Kernel for A64 git - by Miguel Campos - 03-25-2018, 03:49 AM
RE: Kernel for A64 git - by dkryder - 03-25-2018, 02:16 PM
RE: Kernel for A64 git - by Luke - 03-25-2018, 03:25 PM
  PineA64+: Audio in 5.0 Kernel puzzles 6 13,704 11-13-2019, 09:41 AM
Last Post: roel
  Rockpro64 NFS root mount (kernel 4.20) - ethernet help? tenspd137 0 4,046 12-06-2018, 01:14 AM
Last Post: tenspd137
  NVMe and new kernel bjbb17 0 3,620 09-25-2018, 03:39 PM
Last Post: bjbb17
  Real-time linux kernel Artyom 45 101,245 09-11-2018, 01:08 AM
Last Post: zzwpine
  DKMS on kernel 3.10.107-pine64 obrienmd 5 12,102 06-21-2018, 05:45 PM
Last Post: evilbunny
  Gentoo for pine64 - longsleep kernel incoherent 0 4,808 12-09-2017, 08:14 AM
Last Post: incoherent
  [SOLVED] UEFI + Fedora Mainline Kernel Booting! cztian 0 4,398 07-13-2017, 08:38 PM
Last Post: cztian
  Mainline kernel [Solved] jeroen79 11 25,543 02-08-2017, 06:19 AM
Last Post: umiddelb
Question Need help : Issue in running compiled kernel with tftp+uboot dinesh.bhoyar 2 6,429 01-30-2017, 12:44 AM
Last Post: dinesh.bhoyar
  Jackd triggers kernel warning cztian 0 4,479 09-03-2016, 08:16 AM
Last Post: cztian
