Android 6.0 Tablet and TV (release candidate, maintained)
(03-17-2017, 07:05 PM)DireWolf Wrote:
(03-16-2017, 08:30 PM)simplexdan Wrote:
(03-15-2017, 10:56 PM)DireWolf Wrote:
(02-28-2017, 10:03 PM)simplexdan Wrote: Both On at the Same Time!
simplexdan....can you give me a hand with getting this working on both screens? i can get the lcd working but not the hdmi. What build did you use and di you have to change anything in the boot txt?
  I used Etcher and image android-ver6.0.1-lcd-version-20170209-pine64-64GB. Edited from windows the uNev to
# To enable LCD, uncomment:
 pine64_lcd=on
Make sure there is a space before pine64. BUT I have still not got audio to work, but have a lead with this:
"We can make the audio works via HDMI by modifying the audio_policy.conf in /etc (rooted image) : change default_output_device (Global Configuration) to: AUDIO_DEVICE_OUT_AUX_DIGITAL.
At that time the audio works both of HDMI and 3.5mm jack"
When i flash this img onto an sd card my pc won't let me edit on files. is there a command prompt i need to use? Also i can't get any usb to recognize while running android.
  It all matters what img you are using. The 6. and 7. had the base iso in first position so can edit them with no external devices. Once you put it in the pine though, you will no longer be able to read it. Working on a boot USB with linux on it to make it easier.
RE: Android 6.0 on Pine A64 - by neyron - 11-26-2016, 05:21 AM
RE: Android 6.0 on Pine A64 - by Luke - 11-26-2016, 05:52 AM
RE: Android 6.0 on Pine A64 - by trenton4k - 11-26-2016, 09:07 AM
RE: Android 6.0 on Pine A64 - by ayufan - 11-26-2016, 10:20 AM
RE: Android 6.0 on Pine A64 - by mhump711 - 11-26-2016, 12:41 PM
RE: Android 6.0 on Pine A64 - by ayufan - 11-27-2016, 04:51 AM
RE: Android 6.0 on Pine A64 - by wappi - 11-28-2016, 01:02 PM
RE: Android 6.0 on Pine A64 - by ayufan - 11-28-2016, 01:06 PM
RE: Android 6.0 Tablet and TV (release candidate, maintained) - by simplexdan - 03-17-2017, 08:44 PM
Shocked Remote for Android? liodra 18 29,167 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 16,531 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 6,865 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 6,936 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 5,519 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 3,291 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 253,825 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 3,495 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 103,804 02-10-2019, 07:44 PM
Last Post: mmmarcus
  +LTS/SOPINE Android SDK support and Customization biplab777 1 4,605 01-07-2019, 01:21 AM
