Android 6.0 Tablet and TV (release candidate, maintained)
#62
(12-12-2016, 05:03 AM)Crispin Wrote: Hi, you're probably more technical than I am, but I did see your 'PS' and noticed that info wasn't mentioned in the "steps to reproduce" in the issue tracker, so thought it might be worthwhile suggesting here (I know I've been caught with similar things in the past!). So have you tried:
a) plugging the drive directly into Pine64 without the USB hub?
b) a USB 2.0 drive?
I don't have a Pine assembled at the moment or I'd try these myself, especially since I'll need this feature too on ayufan's great Android 6 build, too. So please let us know how you get on!  Smile
Thanks for your help Crispin.
I've managed to get Android (and ES File Explorer) to recognize and mount the disk using a single FAT32 or NTFS partition using MBR partition table.
However now I'm having another issue: Kodi is unable to detect the USB drive so I can't play any files stored on this drive from Kodi.
I've also tried manually browsing from Kodi to /mnt/media_rw/0A67-1313 (where the disk partition gets mounted by Android) but Kodi seems unable to open the /mnt/media_rw directory (dmesg reports an access/permission denied error or something along those lines; I'm not at my PC right now and I can't check).
I'll try to investigate this further and I'll report here if I'll make any progress, but I'm very busy with work these days and I'm not sure if/when I can do that.
RE: Android 6.0 on Pine A64 - by neyron - 11-26-2016, 05:21 AM
RE: Android 6.0 on Pine A64 - by Luke - 11-26-2016, 05:52 AM
RE: Android 6.0 on Pine A64 - by trenton4k - 11-26-2016, 09:07 AM
RE: Android 6.0 on Pine A64 - by ayufan - 11-26-2016, 10:20 AM
RE: Android 6.0 on Pine A64 - by mhump711 - 11-26-2016, 12:41 PM
RE: Android 6.0 on Pine A64 - by ayufan - 11-27-2016, 04:51 AM
RE: Android 6.0 on Pine A64 - by wappi - 11-28-2016, 01:02 PM
RE: Android 6.0 on Pine A64 - by ayufan - 11-28-2016, 01:06 PM
RE: Android 6.0 Tablet and TV (release candidate, maintained) - by vially - 12-12-2016, 07:24 AM
Shocked Remote for Android? liodra 18 29,599 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 16,762 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 6,972 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 7,037 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 5,601 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 3,335 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 257,192 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 3,546 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 104,886 02-10-2019, 07:44 PM
Last Post: mmmarcus
  +LTS/SOPINE Android SDK support and Customization biplab777 1 4,670 01-07-2019, 01:21 AM
