No more ethernet with linux... Android connection is fine?!?!
Maybe your router/modem doesn't like the fact that the MAC address on the ethernet is changing every time you switch between linux and android? Although that shouldn't really matter since you need to power down the board before removing the card and changing OSs, so i would have thought that resolved it issue. As far as long delays with the longsleep images without the ethernet plugged in, that is sue to /etc/network/interfaces listing auto eth0 instead of allow-hotplug eth0, making it so the init process waits for 5 minutes before continuing if there is no ethernet cable plugged it.
Are you able to get the wifi up on linux on a internet connected wifi network? Then you could run sudo apt-get ethtool so you don't need to neuter a ethernet cable.
RE: No more ethernet with linux... Android connection is fine?!?! - by pfeerick - 11-09-2016, 05:03 AM
  NEMS Linux 1.5 Released for A64/A64+, A64-LTS/SOPine, Rock64, RockPro64 (NAGIOS) Baldnerd 4 14,338 03-28-2020, 06:20 PM
Last Post: ty1911
  Howto run Linux with resolution other than 1080p longsleep 28 83,026 06-13-2019, 01:53 AM
Last Post: Nilda
  NEMS Linux for Pine A64 (+) Luke 1 8,008 05-09-2019, 05:42 PM
Last Post: pineadmin
  Pine Board using linux stuck during boot sequence ktaragorn 4 12,517 03-30-2019, 06:48 AM
Last Post: ktaragorn
  Gentoo Linux test image xalius 23 61,932 01-28-2019, 11:05 PM
Last Post: necrose99
  Rockpro64 NFS root mount (kernel 4.20) - ethernet help? tenspd137 0 4,046 12-06-2018, 01:14 AM
Last Post: tenspd137
  Real-time linux kernel Artyom 45 101,247 09-11-2018, 01:08 AM
Last Post: zzwpine
  linux distribution hazerty 3 8,654 04-01-2018, 02:48 PM
Last Post: dkryder
  Linux Web Server OS harcrow 2 7,795 01-30-2018, 10:26 AM
Last Post: Rustproof
  eta linux image?? firosiro 1 5,688 08-03-2017, 10:05 PM
Last Post: pfeerick
