No more ethernet with linux... Android connection is fine?!?!
Question
Pine64 with 2G memory and the wifi/bluetooth pcb on, DC-in through the euler-bus.
Recently I was only using android 5.1.1 for its stable wifi connection and decided to try again the linux images for the added apps... Surprisingly ethernet is not working anymore on the linux images I tested: Longsleep's old xenial-pine64-bspkernel-20160507-1, newest xenial-pine64-bspkernel-20160716-1, xubuntu-xenial-mate-20160528-longsleep-pine64-8GB, Armbian_5.20_Pine64_Ubuntu_xenial_3.10.102...
For some reason linux builds do not recognize/work with the ethernet connection anymore...
Regarding Longsleep's console-only images, I have to wait few minutes for the login thing to appear. For the 'desktop' images, I login then it says that I'm not connected... It happens even if the cable is connected directly to the main router (no switch). I'm 200% sure that it was working before, I installed Mate from Longsleep's console image...
What is going on?!?!
No more ethernet with linux... Android connection is fine?!?! - by cr2016 - 10-21-2016, 04:23 AM
  NEMS Linux 1.5 Released for A64/A64+, A64-LTS/SOPine, Rock64, RockPro64 (NAGIOS) Baldnerd 4 14,327 03-28-2020, 06:20 PM
Last Post: ty1911
  Howto run Linux with resolution other than 1080p longsleep 28 82,926 06-13-2019, 01:53 AM
Last Post: Nilda
  NEMS Linux for Pine A64 (+) Luke 1 7,998 05-09-2019, 05:42 PM
Last Post: pineadmin
  Pine Board using linux stuck during boot sequence ktaragorn 4 12,504 03-30-2019, 06:48 AM
Last Post: ktaragorn
  Gentoo Linux test image xalius 23 61,877 01-28-2019, 11:05 PM
Last Post: necrose99
  Rockpro64 NFS root mount (kernel 4.20) - ethernet help? tenspd137 0 4,029 12-06-2018, 01:14 AM
Last Post: tenspd137
  Real-time linux kernel Artyom 45 101,081 09-11-2018, 01:08 AM
Last Post: zzwpine
  linux distribution hazerty 3 8,615 04-01-2018, 02:48 PM
Last Post: dkryder
  Linux Web Server OS harcrow 2 7,767 01-30-2018, 10:26 AM
Last Post: Rustproof
  eta linux image?? firosiro 1 5,667 08-03-2017, 10:05 PM
Last Post: pfeerick
