Questions. board serial.?
(09-11-2016, 12:38 AM)bongky youn Wrote: Replication SD card -> pine64 put on other cards boot -> boot Prevention
Program Running -> Import to come to the board a unique number comparison -> incorrect shutdown -> correct execution
A unique code that is needed to make the pine64. How to import or shine?
When the label is printed on the bottom of the board there are two numbers pine64
Each board is wrong. Can a function to obtain this number from Linux ubuntu.?
Or how you can get is ?
If I understand your question correctly, you want to know what the serial number of your pine64 boards are? Is that correct?
When you have a board with two numbers (with bar codes) on the back, the top number (which has numbers only) is the serial number for that board. The bottom one (which will have numbers and letters) is the hardware MAC address for the ethernet.
If you wish to access the serial number via the file system  on linux, I can not help you with that.
Questions. board serial.? - by bongky youn - 09-11-2016, 12:38 AM
RE: Questions. board serial.? - by pfeerick - 09-11-2016, 12:58 AM
RE: Questions. board serial.? - by bongky youn - 09-11-2016, 01:19 AM
RE: Questions. board serial.? - by pfeerick - 09-11-2016, 02:18 AM
RE: Questions. board serial.? - by bongky youn - 09-11-2016, 02:07 PM
RE: Questions. board serial.? - by pfeerick - 09-11-2016, 09:43 PM
RE: Questions. board serial.? - by bongky youn - 09-11-2016, 10:56 PM
RE: Questions. board serial.? - by bongky youn - 09-12-2016, 09:24 AM
  I2C Expansion Board DonFL 39 57,874 08-16-2022, 10:29 AM
Last Post: AndrewC78
  Poll: interest for SPDIF-only POT board? amp 0 2,593 05-01-2019, 11:17 PM
Last Post: amp
  Audio DAC pot board nejec 2 6,500 12-09-2017, 01:43 PM
Last Post: nejec
  Zwave Board: 300, 400 or 500? Lugor 4 8,456 01-10-2017, 08:55 PM
Last Post: Lugor
  USB serial and UART Pajeet 1 3,310 09-14-2016, 05:28 AM
Last Post: HayseedGeek
  My Board Layout Diagram UnixOutlaw 8 12,966 09-09-2016, 02:41 AM
Last Post: pfeerick
  New module: POT board Crispin 25 40,729 07-12-2016, 08:47 PM
Last Post: khgoh
  GPS expansion board stephen fleming 3 5,882 07-06-2016, 11:20 AM
Last Post: xalius
  General Battery Questions nspireing 11 16,290 07-03-2016, 03:15 AM
Last Post: pfeerick
  Few Hardware Questions dav3yb 3 5,996 03-20-2016, 11:06 AM
