09-10-2016, 11:23 AM
(09-10-2016, 10:54 AM)Bluphire Wrote: what pitch is needed for this application? I'm overwhelmed looking for the adapter, any help?
There is nothing overwhelming about engineering; just break the problem down into byte sized pieces, plan, do the math, execute.
The responsibility for the specs and planning is yours. When I measure the connector it is 3.5mm wide and the pitch is 0.5 mm (this is fairly standard) (I'm actually measureing my tp connector)
In other words, if you were to lay a clear mm scale on the cable looking down at the connectors the mm markings on the scale would line up with every other connector pattern. The connector's 'pitch' is 0.5 mm from center to center.
Hope this helps you.
marcushh777
please join us for a chat @ irc.pine64.xyz:6667 or ssl irc.pine64.xyz:6697
( I regret that I am not able to respond to personal messages; let's meet on irc! )
