RTC Backup Battery Holder CR-2032 Issues
The discussion is 'stupid' because there shouldn't even BE a discussion about something like this.
... the case is clearly designed for serial installation and modified for parallel installation. The black wire is not soldered where it can be effective (should be at the center), and the switch is more than likely soldered wrong too.
The good news is that the case can easily be corrected to function normally.  The bottom line is that the red lead must be positive, and the black lead negative... and with both cells installed the voltage must not be greater than 3v.
What a fit.
Thank you for graciously posting the pics; my sincere apologies for thinking you were pranking... this is just unbelievable.
RE: RTC Backup Battery Holder CR-2032 Issues - by MarkHaysHarris777 - 09-07-2016, 01:44 PM
  PineA64 battery in Germany (specifications or alternatives) burningkrome 0 3,116 12-02-2018, 04:10 AM
Last Post: burningkrome
  Lithion 3.7 volt PineA64 battery Model 9070120P MarkHaysHarris777 9 14,260 12-10-2016, 10:01 AM
Last Post: mcrognale
  Battery Backup for media center. Zone 4 8,274 09-13-2016, 09:08 AM
Last Post: MarkHaysHarris777
  Battery Power clackamas 3 7,229 06-13-2016, 02:18 PM
Last Post: clackamas
