Perfect ABS Plastic Server Enclosure from Radio Shack
(09-24-2016, 10:49 AM)Bluphire Wrote:
(09-23-2016, 01:53 AM)Prince3121 Wrote: Cool
Finally, have most of the hardware, to build my Pine64 into the ABS enclosure. This is only temporary, as I'm hopefully, sourcing a C4 Labs enclosure, via a travelling friend.
My Parts List so far:
ABS case 195x110x60mm, only size I could get.
M3 30mm nuts and bolts
5V DC fan to follow
2N2222 transistor
LEDs
Power and Reset Micro-switches
Extra HDMI Cables.
Pity about the only HDMI video support, as I have an old LCD VGA screen, which I used with my RPi 3, via the VGA to HDMI adapter. Luckily, I have an LG LCD monitor with a HDMI input, which works perfectly. I even tried a DVI to HDMI adapter to fit my old AOC 22" Screen, but no luck there.
Will attempt to get everything put together and mounted by this weekend. I have already installed and started up the Pine64, with the Android and now Ubuntu image loaded onto the Microsd card, successfully. Think I will play a little first before deciding what project to attempt with it.
Big Grin
Did you happen to see C4's solution to the LCD enclosure?
http://forum.pine64.org/showthread.php?tid=1682 (page 7)
Matt
Ok cool. Will check it out.
Thanx.
RE: Perfect ABS Plastic Server Enclosure from Radio Shack - by Prince3121 - 09-30-2016, 01:12 AM
Video 7" LCD wooden framen enclosure for Pine64 *UPDATED WITH killor 12 19,861 10-12-2018, 03:08 PM
Rainbow (Cluster) Modified Playbox Enclosure Progress predominant 3 5,453 06-17-2017, 01:29 AM
Last Post: pfeerick
  Nostalgic enclosure VHS carlo318 4 7,513 03-05-2017, 04:56 PM
Last Post: carlo318
  How is the battery Supposed to be mounted in the PlayBox enclosure? dbarbee 2 5,688 02-12-2017, 10:17 PM
  Enclosure for flush-mounting the 7" touchscreen Learnincurve 9 12,958 02-07-2017, 08:45 PM
Last Post: Bluphire
  Official C4 Labs LCD Enclosure *UPDATED WITH ASSEMBLY VIDEO* Bluphire 12 24,899 01-06-2017, 03:15 AM
Last Post: Learnincurve
  Tablet Enclosure Vachtra 11 19,949 12-20-2016, 07:17 AM
Last Post: Toriless
Rainbow PineA64 Home-Brew card-board Play Box for Android & LCD Enclosure MarkHaysHarris777 9 18,975 11-01-2016, 06:23 PM
  White box plastic enclosure clawinus 3 6,603 10-13-2016, 08:47 AM
Last Post: Bluphire
Rainbow DMG/Classic Gameboy Enclosure!? n_n' Gearsoul 54 65,555 09-16-2016, 12:21 PM
Last Post: Ghost
