Adafruit 16x2 LCD doesn't turn on with Pine64
(08-25-2016, 08:53 PM)MarkHaysHarris777 Wrote: i can see from your print-out of the i2c registers that it is not detecting the address of the LCD.  How are you powering it?  Double check your connections.  Make sure its on the correct bus...
Mark, I think you need to have a another look at the first post, specifically the picture... you can clearly see the LCD is on a Adafruit LCD Pi Plate, meaning it is i2c, with all comms and power comming from the pi bus. Plus, there is no room for incorrect wiring as assembly is as simply as place LCD here and solder connectors, etc.
My question here would be does I2C work out of the box with a particular debian or ubuntu image, and if not, what configuration is needed to get it up and running?
  Pine64 and Nexdoc mcf 11 25,263 12-05-2017, 03:10 AM
Last Post: Pander
  Mounting RPI3 "hats" on Pine64 gczuczy 5 13,810 07-30-2017, 10:29 AM
Last Post: KnReLe
  adafruit ultimate gps hat mrjake 3 9,206 02-16-2017, 08:15 PM
Last Post: mrjake
  Analog Amplifier for Pine64 mbt28 2 6,869 02-09-2017, 08:46 AM
Last Post: mbt28
  ZJ080NA-08A and pine64 mbt28 4 9,290 10-10-2016, 05:12 AM
Last Post: mbt28
  Euler bus/Pi2 bus on Pine64 xxvolwarexx 1 7,008 10-05-2016, 06:35 PM
Last Post: pfeerick
Exclamation Pine64+ not starting (never) Alex89cgn 1 4,537 08-15-2016, 12:05 PM
Last Post: MarkHaysHarris777
  Pine64 Eagle LBR openhardwarecoza 3 7,683 08-01-2016, 11:05 AM
Last Post: xalius
  Setting up UART2 for Adafruit GPS hat stephen fleming 1 4,818 05-13-2016, 03:20 PM
Last Post: peterz
